Pa d1000.1
SDA1C
Has anyone tried the PA D1000.1 on a set of sealed 12" kickers in parallel?
Too much **** to list....
Post edited by SDA1C on
The PA D1000.1 is stable down to 1 ohm. If the Kickers are DVC then you can then you can set the VC on each sub to a 2ohm load and then connect them in parallel to get a 1 ohm load overall and 1200 watts to the subs. 600 watts to each will be plenty. If the subs are SVC then connected in parallel they will show a 2ohm load and each sub will get 400 watts, which is also fine.
There are at least 20 different kicker sub configurations...which one are you referring to?
exalted512 wrote: »There are at least 20 different kicker sub configurations...which one are you referring to?
-Cody
Any. I haven't bought them yet. I am looking for any word on which setup would be best. The smaller the box the better. I want to try the D1000 is about as far as I have gotten.Too much **** to list.... -
then why kicker specifically?
