Methods to stop the bass going below the floor ?
polkfarmboy
Is there anything that can be used under a pair of tower speakers to lessen the bass thump through the ceiling below
Post edited by polkfarmboy on
- Sound proof insulation in the ceiling below your speakers.
- Spike speakers.
- Isolation foam platform of some kind. -
Something like: Auralex SpeakerDude (may help)
Dude! Pun intended!
I have an Auralex SubDude under my sub and it made a very noticeable difference. At the time it was thick carpet over hardwood with a basement below. I have removed all the carpet and left it sitting on the SubDude.
$50-$60 or so on Amazon. If you have a really big sub, you'll want to look at an Auralex Gramma or Great Gramma. -
Why?
To keep from bothering your neighbors? Not much will help that beyond sound deadening material in the floor/ceiling and even that won't completely stop a low frequency signal
To keep something from vibrating or rattling on the floor below say a two story house, then perhaps a foam base or spikes, etc.
To keep from bothering people in neighboring apartments, there really is nothing beyond turning the bass down or using a speaker that doesn't reproduce low bass, like a small bookie.
Headphones...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Stop listening to that annoying thump thump garbage.If you can't hear a difference, don't waste your money.
Dude! Pun intended!
cnh
Here it is;
http://www.amazon.com/Auralex-SpeakerDude-Speaker-Isolation-Platforms/dp/B00266HBSU/ref=cm_cr_pr_sims_tSet up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
polkfarmboy wrote: »Is there anything that can be used under a pair of tower speakers to lessen the bass thump through the ceiling below
Did ya get that knock on the door at midnight ?
Scary lookin' sweaty, hairy Greek dude in a t shirt with a pipe wrench in his hand....maybe ?HT SYSTEM-
lsi 9's -
+1.nooshinjohn wrote: »Headphones...
Bass is non-directional. The only device I've seen that claims to make directional bass is this: http://www.edesignaudio.com/product_info.php?cPath=2_119&products_id=607"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Move out of an apartment and get a house.
Not many options with an apt. You can try putting a big piece of tile under each speaker (I'm assuming the floor is carpeted). More realistically is to move to a bottom apt. or rent a townhouse or house.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
Try some plain old hockey pucks under the speaks. They work as well as a high dollar iso piece. I have them under my Spires and barely hear it when I'm in the basement.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Move to the lower floor so you can raise hell with the jackass above you..........HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Once the judge lifts that restraining order keeping you away from the sheep, you can always go back to the farm.
:razz: The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Time for a town house with a basement."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Simple,reverse the polarity of the cables at the speaker terminals on channel.Done bass worries gone.
LOL
Such a funny topic. -
Funny!Simple,reverse the polarity of the cables at the speaker terminals on channel.Done bass worries gone.
LOL Maybe sell him that bass absorber thingy you built and he can give it to his neighbor.:cheesygrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
