Is this a lateral move ?
k0tuynh
k0tuynh Posts: 144
edited April 2012 in 2 Channel Audio
Between HCA 2205A and B&K ref. 200.1 mono for 2ch.?
http://app.audiogon.com/listings/b-k-ref-200-1-black-mono-amps
Thanks,
Post edited by k0tuynh on
  • thsmith
    thsmith Posts: 6,082
    edited April 2012
    IDK but it could be fun to find out. Gadabout has b&k so hopefully he will weigh in, a lot people here us parasound amps.
    VR3 Posts: 29,662
    edited April 2012
    B&K is very sterile sounding in comparison to Parasound which I would say is a warmer sound...
    Comparable quality, depends on your taste
  • k0tuynh
    k0tuynh Posts: 144
    edited April 2012
    Thanks guys ..still debating whether I should move on from Parasound and try something different.
  • playback
    playback Posts: 101
    edited April 2012
    k0tuynh wrote: »
    Try a HiFi Tunning Supreme or Silver Star fuse on the main line fuse on the Parasound , I did this on Halo A21 with very positive results! Just to get a hint of what a fuse upgrade can do , if you have some Caig progold around clean the stock fuse ends and polish to a shine. I couldn't believe the impact of just cleaning it, needless to say I cleaned every fuse I have in my setup and replaced the one's in my prepro as well!
  • Ern Dog
    Ern Dog Posts: 2,237
    edited April 2012
    playback wrote: »
    +1...
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2012
    VR3 wrote: »
    Seriously, I think you have your wires crossed. :wink: I would so say the Para is more sterile than the B&K.
    It is a pretty lateral move though.
    heiney9 Posts: 25,612
    edited April 2012
    Lateral in that you might not notice a significant improvement. But trying all different kinds of gear (especially when used prices are involved) is how you get to know what attributes you like and don't like. So you might just want to try it out especially if you can flip either one for little to no loss.
  • k0tuynh
    k0tuynh Posts: 144
    edited April 2012
    heiney9 wrote: »
    That's what I thought. In fact, I just pulled a trigger on B&K 200.1 S2 for $900 plus shipping. Will try them out then decide which one I should keep.
