REL sub connections
kevhed72
kevhed72 Posts: 5,146
REL has a unique sub connection (the name escapes me right now) which for 2-channel, connects directly to the amp. Can this same connection be utilized by HT vs. the LFE input on the sub.....I am assuming using both the 'unique' input (Speakon) for 2 channel and the LFE input at the same time may not be possible. Anyone have experience dual utilizing these subs? thx...
Post edited by kevhed72 on
  • polkatese
    polkatese Posts: 6,767
    edited March 2012
    http://forum.audiogon.com/cgi-bin/fr.pl?bhome&1270151700&read&keyw&zzrel
    I think I tried both back when I just got my Storm III back in 2002 and thought it was good. Since then, I only used Speakon Neutrik exclusively to supplement LSi15.
    Give it a try on both...
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Conradicles
    Conradicles Posts: 6,343
    edited March 2012
    You can use both if the sub is in a H/T system.
  • kevhed72
    edited March 2012
    Good deal.....thanks. I think I am going to put my DSW PRO 600 up for sale and try to PU one of the 8 or 10" driver RELs. (Room is on the small size).
  • Conradicles
    edited March 2012
    Vann's has the REL T2 for $399 now:
    http://www.vanns.com/shop/servlet/item/features/549798122/rel-t2-black?s_c=site_search
    Looks like a deal to me...you could add a second one in the future when funds allow...Enjoy!
  • mantis
    mantis Posts: 17,419
    edited March 2012
    Rel's connection is the Speakon Neutrik and basically looked like a balanced connection with 3 speaker wires on the other side which goes to the amp. You get left and right positive and a common ground , pick which side for ground left or right it doesn't matter.
    On the subs back panel you will find setting for crossover points for the Neutrik connection. This must be set to blend in your main channel speakers. Look up the spec's of your main speakers or fronts as called by some and set the Rel's crossover just above the lowest hz your speakers can play. I usually go 10 to 20 above in hz so. This usually yields best results.
    Next up is LFE for home theater. This is the 2nd part of the amps preamp section. It has 2 for both to play at the same exact time. Very unique to Rel which is one of my very favorite music ONLY subs. I don't care much for them for home theater as I always felt they lack a bit for huge explosions and excitement. They are so damn smooth and musical they disappear into the room but lack that punch required for theater. It can be used but I grew up on Velodyne and they are extremely fast tight loud and musical all in one breath. So Run LFE to the sub from your receivers LFE out and set the crossover point to open on the Rel so the receiver can do the cross over point. Set that to 80hz and don't look back. Calibrate your levels with the receiver. Set the del close to level so you can stay as close to 0db on the LFE out @ 75db. This will give the sub plenty of head room and give you some nice theater bass.
    I've been trained by Rel to calibrate their subs some time ago. I loved calibrating them as they are very fun to do.
    Good luck hope this helps.
    Dan
  • pietro944
    pietro944 Posts: 720
    edited March 2012
    WOW....For $399 get this....I have the T5 and for 2 ch music,it's fantastic...peter
  • NewHTguy
    NewHTguy Posts: 584
    edited March 2012
    I paid $399 for the T3 from Vanns. I love mine. Pairs nicely with my Lsi7s. Wish I had waited but, frankly, for my room the T3 is fine. Of course more power is always better.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • michael1947
    michael1947 Posts: 775
    edited March 2012
    This was a lot of help with my REL T3, thanks guys....Now I'm still confused with what to do with my Micro-pro 2000 hook-up. For ht, the LFE in is pretty straight forward however for augmenting 2 channel I'm stumped. The 4 RCA's, in/out, what to do with them. I have read the manual forward and backwards but I still don't get it.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
