Better cable???
amulford
amulford Posts: 5,020
I am kicking around an idea of making some DIY video cables.
I am wondering who makes a better quality stock. I hear (and read) good things about both Belden and Canare. Does anyone have opinions on these?
I don't want to limit myself either of these brands though, if I don't have to. Are there any other suggestions for a quality manufacturer??
Thanks,
Anthony
Post edited by amulford on
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2004
    There is no advantage to using Belden over Canare, just get whats cheaper between the two. They are the two most used DIY cable manufacturers period.
    The connectors should be considered just as important in that project, so don't get cheap in that area. Scosche, WBT, Vampire, Dayton are all good choices.
    I think DIY is a great project and idea, take your time, and the results are damn near a given. The cables will provide fairly predictable, reliable results if constructed correctly.
  • amulford
    edited April 2004
    Thanks.
    How about solder vs. compression type connections? I don't know how good my soldering skills are...
  • mantis
    mantis Posts: 17,331
    edited April 2004
    I perfer compression
    Dan
  • amulford
    edited April 2004
    Thanks fellas...
    BTW what part of PA, Mantis???
