Bi amping?????? Help
welp, guess i get to save time and frustration by not fishing additional wires to passive bi-amp will be using denon 3312 which doesn't seem to be a contender to bi-amp with gains.
my intent would be to get added performance for direct or stereo mode, and then run my HT in 5.1 mode. Not interested in full 7.1 -
In 5.1 Ht mode, if you used the bi-amp theory, then in essence your using 7 channels. Regardless, a seperate amp will give way better results.HT SYSTEM-
lsi 9's -
Here's an example of why, with many AV receivers, bi-amping with just the receiver is pointless:
http://www.hometheater.com/content/onkyo-tx-nr1009-92-channel-network-av-receiver-ht-labs-measures
This is a midrange, $1300 receiver. As you can see with 5 channels driven it puts out 116.5 watts per channel. Up it to 7 channels and it drops to 86.1 watts. So if you biamp you're sending 172.2 watts in theory to the bi-amped speakers, but the remaining 3 channels lose 30.4 watts each. So in theory your bi-amped speakers might sound a bit better if they're power hungry, but you're robbing peter to pay paul.
Most receivers given wattage rating is only with 2 channels driven. It makes it sound more impressive. The above example is rated at 135 watts with 2 channels driven.
Generally the limiting factor in a receiver is the power supply to my understanding. The example above would need more than a 1.2kva power supply just to even approach being able to drive all channels at the rated spec.swizzchard wrote: »welp, guess i get to save time and frustration by not fishing additional wires to passive bi-amp will be using denon 3312 which doesn't seem to be a contender to bi-amp with gains.
Not to muddy this any further, but I can't help myself... Opinions on a passive biamping scenario with slightly better equipment than an entry level ht avr?
SDA SRS
Rotel RSP-1098
Rotel RMB-1075
Signal Cable Ultra speaker cables
Certainly this amp has more power to offer with multiple channels driven than your typical lower end avr . I would like to hear some more feedback.Chris
SDA 3.1TL Denon AVR 3801/Carver TFM 35
SDA SRS 1.2 Chiro C 800/McIntosh MC2002/Oppo BDP 83SE
Monitor 5 -
I agreeIn theory an avr has the capability, but in reality, not so much. It still uses the same power supply in the receiver which at best is fairly weak when using 7 channels. Mind you, not all AVR'S are as weak as I claim, but a good majority in the sub 1500 buck market.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
+2 for the old timers, TB & F1. Good jobs. Now, did I do wrong by bi-amping my SDA-SRS's. When I set up my main HT I was thinking the big boys needed as much power as I could muster up so I ran 2 channels each from my 5 channel Emotiva XPA-5 to each speaker, removing the jumper wire and the 5th channel to my center. It's a big room, 16x22x11(ceiling) and I like my Bruce Willis movies loud so I "biamped" them. It sounds...ok but it feels a little un-balanced with too much center and not enough rear, but I'm sure it's more in the receiver set-up and my mis matched center, a pair of my old Klipsch guys. I think it still needs a lot of work but back to the bi-amping...what is enough for these SRS's???Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
