Can i use a Parasound P3 as a phono only pre?
brgman
Until i get a new phono pre can i run my TT into the Parasound P3 i have then run the outputs to my Joule then to the amp.
I am trying to avoid having to keep switching my amp inputs.
Is this kosher or will it go BOOM!?!?
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
When in doubt, refer to the users manual.If you can't hear a difference, don't waste your money.
This forum IS my users manual!:cheesygrin:Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Main outs... no. Use the P3's "Tape Rec Out" jacks to feed your Joule...
Did the check arrive?More later,
Tour...
Vox Copuli
