Recommendations for DIY interconnect cable.
fjross
fjross Posts: 183
edited March 2012 in Vintage Speakers
I am looking to either make an upgraded SDA interconnect cable or maybe a set of cables for an A-1 dreadnaught. I currently have a stock SDA cable that I am using with MIT S3.3 speaker interfaces. I understand that I would also have to install new BP's as part of the upgrade. Is there any suggestions for a quality wire for a DIY interconnect cable or A-1 cables. If I decide to go the A-1 route is the Canare 411 a suitable choice for the dreadnaught with it's(4) individual wires?
Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
MIT 3.3 Shotgun biwire speaker interface
MIT 3.3 Shotgun XLR interconnects
Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
Polk 3.1 TL's mint/stock (purchased new)
Polk SDA-2's
  • thsmith
    thsmith Posts: 6,082
    edited March 2012
    Yes to all above. I just did Cardas BP, new gaskets, Norez and new sda ic.
    I tried AQ type 4, Kimber cable 4 and 8tc. All where a huge improvement over stock.
    Stayed with kk 4tc.
    I will add another when I make my AI.
    BP and cable are one of this tweaks you wished you had done sooner. If you upgrade BP I recommend Norez or something similar to do at the same time.
  • Conradicles
    Conradicles Posts: 6,424
    edited March 2012
    You can use any RCA cable and strip the outer edge of the pin. Works good without changing your SDA's.
  • fjross
    fjross Posts: 183
    edited March 2012
    thsmith wrote: »
    Stayed with kk 4tc.
    Correct me if I'm wrong, but the 4tc is a (2) conductor wire. Did you terminate both conductors @ 1 bannana jack to go into your BP? I noticed that with the A-1 that one conductor will go to the BP and the other to the LF ground.
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    Polk SDA-2's
  • thsmith
    edited March 2012
    4TC has many conductors that are normally seperated out to make a + and - speaker cable. I used the entire cable for 1 banana plug that goes to the BP that replaced the pin/blade factory connector.
    When I make my AI, I will cut that cable in half and terminate the other ends with bananas that will go to the AI and BP that was the Pin/Blade. I will then buy another 10' KK 4TC that I will cut in half and terminate the end that goes to AI with Bannana and the other end with spade that goes to neagtive post on speaker.
    heiney9 Posts: 25,672
    edited March 2012
    Canare 4S11 (Star Quad)
  • thsmith
    edited March 2012
    heiney9 wrote: »
    Another good choice for SDA IC, have not tried it but many people do and have this cable.
