Turntable?
rromeo923
rromeo923 Posts: 1,513
edited March 2012 in 2 Channel Audio
I have a Sony LX350H I bought a couple of yrs ago for $75. It came with a no name cartridge.
Sounds Ok, plays my old vinyl. However I have been wondering if it can sound better.
A) Should I upgrade the cartridge and stylus/needle or
B) Should I look for another Turntable used
Suggestions??
Budget $200 max
Thanks!
I got static in my head
Post edited by rromeo923 on
  • bmbguy
    bmbguy Posts: 416
    edited March 2012
    Just keep in mind that the turntable mechanics have nothing to do with the sound. The output cables are connected straight through to the cartridge -- so the 'sound' is solely dependent on the cartridge and stylus, and then the phono preamp/amplifier combo.
    All the rest is just there to spin the vinyl! Well, ok, the tonearm qualities can help the stylus track better, but you get the drift.
  • SolidSqual
    SolidSqual Posts: 5,218
    edited March 2012
    bmbguy wrote: »
    Are you insane? You couldn't be more wrong. The mechanic's of the TT have a significant if not equal effect on the sound as the cartridge.
  • bmbguy
    bmbguy Posts: 416
    edited March 2012
    SolidSqual wrote: »
    In your mind, obviously I am. I did say that the tonearm mechanics mattered in tracking accuracy. But electrically, the signal goes straight from the cartridge to the cables. I was just saying that there was no signal processing circuitry inside.
    Excuuuse me.
  • thsmith
    thsmith Posts: 6,082
    edited March 2012
    You forgot about vibration and other aspects of the TT. THE mechanics may cause vibration.
  • bmbguy
    bmbguy Posts: 416
    edited March 2012
    thsmith wrote: »
    Yes, I stand brutally corrected. And you guys all know what I was trying to say.
  • thsmith
    edited March 2012
    I agree there are a lot of factors to consider. $200 is not a lot to work with so I guess a cart will make the most improvement.
    If the op is serious about vinyl they need to save and get a good foundation in a TT then focus on phono stage and cart.
    Add an extra 0 to that 200 and you get in the ballpark, IMO.
  • decal
    decal Posts: 3,205
    edited March 2012
    bmbguy wrote: »
    I understood exactly what you told the OP and it was dead wrong.
  • rromeo923
    edited March 2012
    :cheesygrin:Actually I was hoping to drop a 0 and find something at goodwill:cheesygrin:
  • decal
    decal Posts: 3,205
    edited March 2012
    rromeo923 wrote: »
    Good luck with that one!!!!!
  • markmarc
    markmarc Posts: 2,309
    edited March 2012
    Just add $250 to your budget and get a Rega RP1. That's a good starting point, then if you find yourself head over heels for vinyl you can start climbing the performance ladder.
    Former Staff Member TONEAudio
    2 Ch. System
    Tony M Posts: 11,928
    edited March 2012
    I just went and looked at your TT and it is a nice one for sure if the belt is OK. Looks like a Technics..sl1200 too.
    I wouldn't upgrade the TT just yet, but your records conditions is a questionable factor now. Do you clean them before playing them? If you do check out the Shure 97ex or something like that from JR music world.com.
    Yard sale season is getting under-way and pawn shops sometimes have decent TTs. Craigs list in your area too.
    I bought my best TT from Good will for 15.00 but that was 15 years ago. A Technics SL-1400 in almost perfect shape. The arm doesn't return even though the return button is in the on position. It doesn't start and drop the needle by itself either. Other than that, I love it. I bought a Denon DL-160 from a member here,(starkiller) and a Phono pre-amp from another member here just a few weeks ago,(csmar01). The Denon cartridge is for really clean records. I have another more robust needle for questionable records.
    If your records are dirty and scratchy and pops alot, don't bother spending much if any more until your vinyl is upgraded too.
    Look in the for sale thread or post this want again in the wanted section.
    Good luck in your quest.
    edited March 2012
    That's true, there are a lot of old TTs out there that can often be had for a low price if you can do some maintenance. (Heck, I had an AK guy 'give' me an old DUAL he was no longer using a while back!) Then you can spend the bulk of your cash on the Cartridge and needle--which certainly are probably the most important elements for upgrades. Of course, your phono pre-amp and accurate speed, tracking and rumble are also factors.
    But don't let this take you down a "bottomless" rabbit hole because guys who spend 1000s on TTs are really into the law of extremely diminishing returns. Remember the better and better it gets the more you will be aware that you're listening to a surface that has contact with a needle (friction is inescapable as are surface noises). That needle has to touch "something"! And that something is moving, dragging on the needle even if the platter weighs a rather "impractical" and "astonishing" 50lbs and the motor could cut your grass "perfectly" while the platter speed is calculated by the Atomic Clock in Colorado? lol
    cnh
  • AudioGenics
    AudioGenics Posts: 2,567
    edited March 2012
    cool...it is really fun to listen to different turntables and the tonearm- cartridge- cables combinations are endless.
    finding a great used one or from someone that is "upgrading" . happy hunting !
  • TroyD
    TroyD Posts: 13,124
    edited March 2012
    bmbguy wrote: »
    I think I know what you are shooting at there, but, man, on it's face....that's an absurd statement. Again, I know what you mean....once the signal hits the stylus. There are all SORTS of things going on that do matter with a table, pretty much under the header of eliminating/mitigating unwanted vibrations.
    I'd also disagree about the law of diminishing returns. It's my opinion that in terms of a turntable....there is a very palpable difference the more you spend.
    I've said this a million times, unless you know what you are doing....most vintage tables aren't worth the effort. IMO.
    BDT
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2012
    economic theory in an electronic world, save the ritual, rejoice in the annulment.
    RT1
    mhardy6647 Posts: 35,464
    edited March 2012
    SolidSqual wrote: »
    irrelevant/deleted. sorry.
  • gp4jesus
    gp4jesus Posts: 2,019
    edited March 2012
    bmbguy wrote: »
    I think you should get around some Rega, Linn, SOTA, Mission fans. You MIGHT find "turntable mechanics have a LOT to do with the sound."
    Tony
    *all connected w/Premiere ICs
    gudnoyez Posts: 8,201
    edited March 2012
    I would keep looking in the for sale adds or craigslist, I just found a Dual CS5000 with a grado x1 cartridge with little play time on it looks in excellent condition going to check it out tommorow, guys asking $375 but might negoiate, I've always wanted one of those Duals. I found my CRS+ SDA's on craigslist and just got a sanus AFA audio Rack used I'am putting another 2 channel system together for those SDA's that Dual TT and a Sacd player and I'am done. If I get that Dual TT I would be a Happy Camper.
  • rromeo923
    edited March 2012
    Well I so far have bought a new cartridge/stylus AT95E and I am quite happy.
    I have a NAD 3080 Integrated running a Quad of Monitor 7's.
    Crosby Stills Nash and Young Deja Vu sounds amazing!! ( In a vintage 1970's way!)
    edited March 2012
    A NAD with four Monitor 7s. The "must" sound nice. Not an expert on TTs, but I do know that that AT cartridge is pretty good!
    Enjoy!
    cnh
