Bi amping?????? Help
13»
  • swizzchard
    swizzchard Posts: 6
    edited March 2012
    welp, guess i get to save time and frustration by not fishing additional wires to passive bi-amp will be using denon 3312 which doesn't seem to be a contender to bi-amp with gains.
    my intent would be to get added performance for direct or stereo mode, and then run my HT in 5.1 mode. Not interested in full 7.1
    tonyb Posts: 33,066
    edited March 2012
    In 5.1 Ht mode, if you used the bi-amp theory, then in essence your using 7 channels. Regardless, a seperate amp will give way better results.
  • Teseract
    Teseract Posts: 44
    edited March 2012
    Here's an example of why, with many AV receivers, bi-amping with just the receiver is pointless:
    http://www.hometheater.com/content/onkyo-tx-nr1009-92-channel-network-av-receiver-ht-labs-measures
    This is a midrange, $1300 receiver. As you can see with 5 channels driven it puts out 116.5 watts per channel. Up it to 7 channels and it drops to 86.1 watts. So if you biamp you're sending 172.2 watts in theory to the bi-amped speakers, but the remaining 3 channels lose 30.4 watts each. So in theory your bi-amped speakers might sound a bit better if they're power hungry, but you're robbing peter to pay paul.
    Most receivers given wattage rating is only with 2 channels driven. It makes it sound more impressive. The above example is rated at 135 watts with 2 channels driven.
    Generally the limiting factor in a receiver is the power supply to my understanding. The example above would need more than a 1.2kva power supply just to even approach being able to drive all channels at the rated spec.
    swizzchard wrote: »
  • midlife/midfi
    midlife/midfi Posts: 11
    edited March 2012
    Not to muddy this any further, but I can't help myself... Opinions on a passive biamping scenario with slightly better equipment than an entry level ht avr?
    SDA SRS
    Rotel RSP-1098
    Rotel RMB-1075
    Signal Cable Ultra speaker cables
    Certainly this amp has more power to offer with multiple channels driven than your typical lower end avr . I would like to hear some more feedback.
    Chris
    SDA 3.1TL Denon AVR 3801/Carver TFM 35
    SDA SRS 1.2 Chiro C 800/McIntosh MC2002/Oppo BDP 83SE
    Monitor 5
  • gp4jesus
    gp4jesus Posts: 2,016
    edited March 2012
    tonyb wrote: »
    In theory an avr has the capability, but in reality, not so much. It still uses the same power supply in the receiver which at best is fairly weak when using 7 channels. Mind you, not all AVR'S are as weak as I claim, but a good majority in the sub 1500 buck market.
    I agree
    *all connected w/Premiere ICs
  • michael1947
    michael1947 Posts: 775
    edited March 2012
    +2 for the old timers, TB & F1. Good jobs. Now, did I do wrong by bi-amping my SDA-SRS's. When I set up my main HT I was thinking the big boys needed as much power as I could muster up so I ran 2 channels each from my 5 channel Emotiva XPA-5 to each speaker, removing the jumper wire and the 5th channel to my center. It's a big room, 16x22x11(ceiling) and I like my Bruce Willis movies loud so I "biamped" them. It sounds...ok but it feels a little un-balanced with too much center and not enough rear, but I'm sure it's more in the receiver set-up and my mis matched center, a pair of my old Klipsch guys. I think it still needs a lot of work but back to the bi-amping...what is enough for these SRS's???
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
