Good quality jumpers
So with the discussion in the LSi9 Mid bass thread, I would like to invite the community to share there opinions for replacement jumpers over the stock brass ones that are usually included. Many suggest going above a monoprice wire so I'm curious what your suggestions are.
Also, for the MIT boys - Been talking with Joe and will be making payment on a pair of EXp 1 speaker cables for a sick price. My question to you is what to use for jumpers? I don't see anywhere MIT offering such a product.
Post edited by Drenis on
I made these for about 18 bucks. This is an easy DIY that is an improvement over brass:Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Too bad those nanners are made of brass too."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Drenis, I'd recommend Vampire gold plated copper spades from Sonic Craft with your choice of wire."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
According to the Radio Shack website, they are gold plated.
http://www.radioshack.com/product/index.jsp?productId=11938538&clickid=prod_cs#Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Gold plated brass :redface:
(which is most probably exactly the same kind of material used to make stock jumpers).
I made ones of large bare wire, and I could not hear any difference (and I had no brass left in the equation, except maybe the "inputs" connector themself... I don't know what material they're made of)... or maybe it was really subttle. Maybe my RTi4 and Yamaha entry-level receiver wasn't revealing enough to make a difference, so I'll probably try again one day.Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
Receiver: Denon X3500H -
Go to a goldsmith/jeweler, get some plate type jumpers made from low-karat gold (10-12K). finished, done, over! Except....if you opt for silver which will be cheaper, but then, you'll have to polish them every week !
Yes I hadn't forgotten about that. Was looking to see if there was anything readily available for others who may be looking or if anyone knew of a MIT offering. I neglected to ask Joe but trying to look outside the monoprice selection. I'll just reference what you posted in my DIY thread for my desktop setup, thanks. -
Never seen anything from MIT, not necessary to have network boxes on jumpers. Look here lots of alternatives, kinda pricey.
http://www.dedicatedaudio.com/jumper_cable
The Cardas jumper plates look interesting.
pyrocyborg wrote: »Gold plated brass :redface:
...as are the speaker binding posts.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Contact frank at signal cable to see if he can make some custom ones for you. We also get a club Polk discount."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Exactly... that's why I don't understand why people keep on telling that we should remove brass from our equation to minimize the combination of different alloys/metal...
Maybe I wasn't really clear in my message, I didn't remember that those inputs were called binding posts... lol... after re-reading, yeah, I was not clear at all
My speakers aren't bi-wirable, so it's a non-issue for me.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Mine are, so if you want to trade straight across, I'm up for it. I'll even drive to Sierra Vista ;-) -
I wish I would have kept the dudes email I got the speakers from (Scottsdale), he looked like he was on a speaker finding mission, based on other recent sales he had. He sure kept these absolutely minty, and a damn good price.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Not on anything here....as are the speaker binding posts.
And besides, why keep adding more brass to the signal path?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
What about using some speaker wire that has been separated, from post to post? I never understood why more people don't do that and use some nanners from there amp? May be a dumb thought, but it seems to be the simplest solution....
You on a mission or something? It was simply an example of some DIY jumpers I made. That ok with you?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Buy enough to make up 2 three wire (twisted) lengths.
http://www.ebay.com/itm/Solid-10K-Yellow-Gold-20-Gauge-wire-/220542939477?pt=LH_DefaultDomain_2&hash=item3359623155 -
I'm actually pretty happy with my LSi9 setup right now, although I would love to try some Harbeths at some point, maybe in a yet to be built 2-channel setup. I am interested in how you found this person in the first place, though. There certainly isn't much nice stuff to be found on craigslist in Phoenix. -
On Audiogon, looking for used 7ES's. Just dumb luck that he was in Az. The Lsi9 is a nice speaker, I like it's visceral sound character. First time I heard it, I went slack-jawed for a moment; my first thought was that they sounded BIG.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
That was my impression of Lsi9s also at the CAS but.....they were being powered by Doro's Godzilla amp, maybe that helped a tiny bit.:cheesygrin:
I made my own jumpers, after the crap Steve caught, I'm a little hesitant to post them.......oh well, what's a little negativity among fellow posters?
Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
There will be NO cable debates in this thread.
I am still working on mine. Hoping to have em done this weekend since my wife works both Sat and Sun so I can get em heatshrinked and covered with nylon techflex
. Will post pics when done. "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Anyone try these? I just stumbled across them: http://shop.mapleshadestore.com/Clearview-Biwire-Jumpers/productinfo/JUMPER/
It looks as if your speaker cables are going through the bottom posts then feeding jumpers to the top? Is that not the wrong way around ? -
polkfarmboy wrote: »It looks as if your speaker cables are going through the bottom posts then feeding jumpers to the top? Is that not the wrong way around ?
Don't think it matters as it looks to be the same emo speaker wire. Otherwise if it was like MIT I would attach to the highs and jumper the lows"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Just stating the obvious, that's all...nothing personal."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
MIT makes jumpers, they just don't list them on their site. Call Joe Abrams and he'll take care of it.Political Correctness'.........defined
President of Club Polk -
Left: Polk LSiM707 with stock jumpers
Right: Polk LSi15 with Signal jumpers
Close-up shot of Signal jumpers on that LSi15:
Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000
