Crappy Rocketfish cables.
camp21178
camp21178 Posts: 273
A few months ago when I got my first surround receiver, I had to unplug my HDMI cable from my TV. When I pulled on it, the connector separated. A few weeks ago I had to pull my Blu Ray player out and turn it sideways and my connector separated. Both were Rocketfish 6 foot cables. I've been into HI-Fi since 1975 and I've never lost a cable of any kind before. Anybody else have this problem? Also, since I need cables, are the Monoprice cables good? I know it sounds dumb, but I want a green one and a purple one. What the heck. Thanks!
Post edited by camp21178 on
    F1nut Posts: 51,778
    edited March 2012
    Maybe you should invest in some quality cables instead of the budget stuff......just saying.
  • Syndil
    Syndil Posts: 1,582
    edited March 2012
    I use Monoprice cables almost exclusively. They work very well.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited March 2012
    You get what you pay for although that isn't always the case.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • gdb
    gdb Posts: 6,012
    edited March 2012
    I got rock solid HDMI cables from Amazon with ferrite whatevers for 4 or 5 bucks that does bluray on a 1080p plasma just as well as the $80 one that I returned. I don't even like the name "Rocketfish" and as such, would have never bought them on that basis alone !:lol: I think the ones linked below are the ones I got....
    http://www.amazon.com/Speed-Category-Certified-Cable-28AWG/dp/B001F37I06/ref=sr_1_21?s=electronics&ie=UTF8&qid=1330754755&sr=1-21
    Maybe you can get some flexi stuff to cover em in your colors !?!?
    tonyb Posts: 33,072
    edited March 2012
    Can't wait for the "I'm not spending 1000 bucks on a cable" crowd to chime in. According to them, it's either 10 bucks or 1000 bucks, nothing inbetween.
    I did have to laugh at the "I want a green and purple one". LOL !!
    Camp buddy, thanks for the late night laugh. Seriously though, Signal cable is a good place to get a cable when your starting out. Tell Frank over there your a member here and he just might toss you a discount.
  • Syndil
    Syndil Posts: 1,582
    edited March 2012
    10 bucks? That's too expensive.
  • gdb
    gdb Posts: 6,012
    edited March 2012
    Syndil wrote: »
    Mine is only $4:lol:
  • Syndil
    Syndil Posts: 1,582
    edited March 2012
    Then you overpaid 50 cents!!
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=3992
    Just kidding. Monoprice charges shipping.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited March 2012
    tonyb wrote: »
    How is that any different than those who make or buy cables with Techflex on them? I get a laugh out of those too.
  • camp21178
    edited March 2012
    Thanks for the replies. A couple of guys helped and a couple ripped me for buying cheap cables, just about the ratio I expected. I bought those cables many years ago before Blu Ray was catching on and I had a DVD player with HDMI output. I've learned a lot since then.
    F1nut Posts: 51,778
    edited March 2012
    I was referring to Monoprice, not Rocketfish.
  • rebuy
    rebuy Posts: 695
    edited March 2012
    I'm not spending 1000 bucks on a cable.
    heiney9 Posts: 25,433
    edited March 2012
    I have had great luck with Media Bridge Ultra HDMI cables.
    http://www.amazon.com/Mediabridge-Ultra-Ethernet-Certified-Available/dp/B0019EHU8G
    I use MIT cables exclusively for audio applications.
  • JustinHEMI
    JustinHEMI Posts: 198
    edited March 2012
    Another often overlook, but terrific source of cabling, is Blue Jeans. www.bluejeanscable.com
    I've personally been using them since about 2007.
    Fronts: Polk RTi A9's
    Center: Polk CSi A6
    Surrounds: Polk FXi A6
    Sub: Epik Empire
    Receiver: Onkyo TX-NR809
    Amp: Emotiva XPA-3
    Blu Ray: Panasonic DMP-BD210
    Power: Monster HDP 2500
    Monitor: Panasonic TC-P60ST30
  • jaggman
    jaggman Posts: 1
    edited March 2012
    I know how you feel, but it cost for quality...
    Jaggman
