Geoff's cabinet upgrade/isolation shelf
After taking comments and suggestions under advisement, I added a shelf for my bluray player.
I know there are some that don't like the placement of my sub, but so far, I'm pretty happy with the results.
I put Tron Legacy back in had to crank it to -18 with the sub at +5 to get the water to jiggle even a little bit (glass of water on top of rack next to center speaker, above the bluray player) during the grid scenes.
Normal listening volume is between -35 and -25 with the sub between -3 and +3. So with the volume set at -18 and the sub at +5, my bar was rattling at the back of the room, but the movement from the water on top of the rack was at a minimum, almost nonexistant. So at normal listening levels, there's no vibration, at least not to the naked eye. I'm very impressed with this sub.
So, here's the shots of the new shelf, note the little buffer pads at the joints.
Post edited by Geoff4rfc on
Looks great Geo!
And for your sub placement,as long as it sounds good to you is what matters.Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player -
Hey Geo,
the columns that hold the blue ray tray..
they are crooked.
You inspired me though. I bought and cut pieces for something like a rack. My entertainment center is too low for my A6 and the tweeters of the A7s are quite a bit higher. I want to lift the center a bit and put something under the rack, perhaps the HTPC..I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.
jeremymarcinko wrote: »But as in all things your perception is your reality. -
I like the new baseboard under the front. Looks much better than the temporary solution.
Always been a fan of having the sub on the same plane as the main fronts. Much easier to integrate the sub into the system as it helps to alleviate phase issues."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
You need a bigger TV or a projector.
Looks good Geoff,enjoy your setup.
Great Geoff! I'm sure it's way better this time, for your bluray player at least! If it sounds as good as before, I'm gonna say:
Enjoy!Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
Receiver: Denon X3500H -
Not for me but kudos for the DIY approach.
