Geoff's cabinet upgrade/isolation shelf
Geoff4rfc
Geoff4rfc Posts: 2,959
edited February 2012 in Speakers
After taking comments and suggestions under advisement, I added a shelf for my bluray player.
I know there are some that don't like the placement of my sub, but so far, I'm pretty happy with the results.
I put Tron Legacy back in had to crank it to -18 with the sub at +5 to get the water to jiggle even a little bit (glass of water on top of rack next to center speaker, above the bluray player) during the grid scenes.
Normal listening volume is between -35 and -25 with the sub between -3 and +3. So with the volume set at -18 and the sub at +5, my bar was rattling at the back of the room, but the movement from the water on top of the rack was at a minimum, almost nonexistant. So at normal listening levels, there's no vibration, at least not to the naked eye. I'm very impressed with this sub.
So, here's the shots of the new shelf, note the little buffer pads at the joints.
Post edited by Geoff4rfc on
  • flyfisher
    flyfisher Posts: 220
    Looks great Geo!
    And for your sub placement,as long as it sounds good to you is what matters.
    Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
    Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player
  • ravaneli
    ravaneli Posts: 530
    Hey Geo,
    the columns that hold the blue ray tray..
    they are crooked.
    You inspired me though. I bought and cut pieces for something like a rack. My entertainment center is too low for my A6 and the tweeters of the A7s are quite a bit higher. I want to lift the center a bit and put something under the rack, perhaps the HTPC..
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • DaveHCYJ
    DaveHCYJ Posts: 89
    I like the new baseboard under the front. Looks much better than the temporary solution.
  • drumminman
    drumminman Posts: 3,396
    Always been a fan of having the sub on the same plane as the main fronts. Much easier to integrate the sub into the system as it helps to alleviate phase issues.
  • SolidSqual
    SolidSqual Posts: 5,218
    You need a bigger TV or a projector.
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    Looks good Geoff,enjoy your setup.
  • pyrocyborg
    pyrocyborg Posts: 524
    Great Geoff! I'm sure it's way better this time, for your bluray player at least! If it sounds as good as before, I'm gonna say:
    Enjoy!
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
  • gtaudio
    gtaudio Posts: 29
    Not for me but kudos for the DIY approach.
