My latest vintage 2 channel setup
cwsmith68
Hafler DH-101 pre
Hafler DH-200 X2
Teac EQA-10
Monitor 10B'S
RTA 12B'S
Technics SL-1350 X2
Pioneer TX-6500II
Pioneer PD-F1009
Kenwood KX-71R
Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
Post edited by cwsmith68 on
Hafler is way cool.
I'm lovin it!Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's -
Looks great. Can't wait till I have room to set up my own Monitor 10s?
Love the Hafler stuff. We used to have a guy up here that sold it "exclusively" along with a Hafler line of tower speakers that were pretty sweet sounding on the Hafler Pre-amps and amps! Also used to sell "used" CDs...don't know what happened to him.
Enjoy!
Luv it!Nice set up.
Very nice set up.Enjoy
Cool gear! I once had that same Teac EQ.--Gary--
I had 2 of these eq's but gave one to my oldest son. It was black. May have to try and trade him out of it to better match the color scheme of the Hafler stuff. But then I would need a black tuner and tape deck! Where does it end??Main system:
show off...lol.....very nice!
Thanks for the comments guys! Hope everyone has a great Saturday! It's bout beer-thirty in Mississippi!:cheesygrin:Main system:
I've always (particularly) liked that little Hafler preamp.
I cannae quite recognize the tt - the color and the big feet thingies remind me of the Technics SL-1650 that my son has. -
Nice collection of gear.Styx
Condo: HK-3490, HK Bridge II, HK BTA-10 Polk TSx500T's -
Nice to see appreciation for Hafler and Polk. My main 2 ch system is a Hafler DH-110 preamp, DH-500 power amp, and SDA-2B speakers.
My backup 2 channel system is a Hafler DH-101 preamp, DH-200 power amp, and RTA-12B speakers.
I've noticed vintage Hafler gear seems to be selling well on the auctions so people must be catching on. -
Wicked-cool setup, love that vintage audio.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks again guys for the comments. I love the sound of my RTA 12b's with the Hafler 101 pre and 200 amp. Loved it so much I bought another 200 for my monitor 10b's!Main system:
Thinking about updating/upgrading the phono stage on the 101 pre. I have some hum/noise in it. Anybody seen these kits selling on e__y for this and have any thoughts of using these? Or should I ship it to someone to have it done?Main system:
See if you can't find a DH-110. I think that's a step-up, and staying within the Hafler framework.
I think I will swap my Carver C-11 and see how I like that setup and see if the hum/noise is gone. I just like to simplicity of the 101.Main system:
Nice very Nice love the vintage stuff, you got it going on there.Home Theater
Swapped the C-11 in place of the 101 and hum is still there. Must be in my turntable
Also, the Hafler sounds much better to me than the Carver. May put it up for sale. Where should I start on the turntable? I put new cables on it and did the ground wire removal mod. New tonearm cable??Main system:
Don't panic. Now, why did you remove the ground wire?! The hum is likely either ground loop, insufficient shielding, or induced AC from another source.
Ground loop. That's why they put ground wires on the tts. Do you have any clipleads? Start grounding stuff to stuff (tt to preamp, or power amp, or power amp to preamp). Your goal - eliminate ground loops. Assuming a nonpolarized plug on the tt; try reversing it in the AC power mains socket. You can also try this with any component(s) with nonpolarized plugs. One configuration may reduce or eliminate the hum.
New cables? They're low capacitance, for turntables, yes? Assuming so... good solder connections at the tt?
The other possibility is induced hum from another source; move stuff around - too close proximity to an AC power supply (more to the point, to a transformer or a wall wart) can induce hum - the culprit in this case could be the preamp, rather than the tt.
Hope something in this list helps! -
If the table you are using is in the lower left of the picture, it may be too close the speaker, especially if MC cart. Transformers close by can cause hum, also.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Thanks! I will try these things and see what happens. I will report back with my results.Main system:
Cool man. I dig Hafler stuff. I have a Hafler 500 for my main two channel system now. Two DH-200s for driving subs and an IRIS preamp and tuner with remote.
Did you ever get your hum issue sussed out? -
Haven't had the chance to do much. But I have deduced that it is in the turntable itself. I'm wondering about replacing the tonearm wire and then
getting one of those plates from KAB to mount and try using different cables.Main system:
So, forgive me if this is a silly question....Do you have both pairs of speakers going at once, or swap back and forth??Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
Inspector 24, I had this issue before I added the second amp and set of speakers. I tried 2 different pre amps and now have it running through an old Realistic STA 2080 all with tye same results. Talking with Kevin @ KAB now about this issue.Main system:
