Anybody find the quality of Adele - 21 atrocious?
24
  • Serendipity
    Serendipity Posts: 6,975
    edited February 2012
    Well, good news. It's not the receiver. Here is a video of my Onkyo doing the same thing - can't turn the volume up to 0dB without it basically sounding like noise. Here it is at -32dB with Adele - Set Fire to the Rain and the sound is already very loud.
    With my classical recordings I can go up to 0dB and over without hearing distortion.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • halo71
    halo71 Posts: 4,630
    This may be a dumb observation. But this is nothing new with the level of some recorded CD's. I turn it up or down depending on CD. So.....where exactly is the beef? Just tonight going from Sting's 'Ten Summoners Tales' to Rush 'Moving Pictures'. Had to back off the volume.
    --Gary--
  • Serendipity
    halo71 wrote: »
    My issue is with the distortion. If you look at the first video I posted, I have the Denon turned up to 0dB on a classical piece and it's sounding great at that level. Nothing's wrong with the system, no blown tweeters, and the sound is really engaging to my ears. Pop in Adele, keep the volume at the same level, and you will go deaf within a short period of time...
    Now in the second video I tried this with my Onkyo receiver. I can turn the volume up to the +dB range on a classical recording, no problem, but keep the volume set at +4 with Adele and ouch!! Painful to the ears.
  • halo71
    halo71 Posts: 4,630
    Please forgive me for asking. But you are just now discovering this? And never noticed a difference in different CD recordings?
    --Gary--
  • Serendipity
    A roughly 30dB difference? No, I've had CDs that were louder and quieter than others, but some of these modern recordings are so loud and filled with clipping it's starting to get ridiculous.
    I have outdoor speakers in the backyard - if I had 4 classical CDs in the changer and one modern "pop" album, when the CD switched over you would hear it 5-6 houses away. Easily.
  • Serendipity
    halo71 wrote: »
    I did some reading and apparently it's not just the level. In the following link, http://www.cutestudio.net/data/products/audio/CD_clipping/index.php, the author writes:
    "As the sound level increases, so does the clipping, and therefore so do the odd order harmonic distortion products, dancing around the mid and high frequencies as a mass of shifting harmonic distortion that increases steeply with volume."
    "The swirling odd-harmonic noise is objectionable to the human ear. This turns a reasonable Hi-Fi format into a dynamic HF noise generator and the effect can only be one thing - people turn down the volume and switch off."
    I mentioned in the first post that I noticed a lot of swirling and HF noise, in the recording.
  • markmarc
    markmarc Posts: 2,309
    I will agree that "21" does suffer from the evils of dynamic compression, you can hear the crunchy top end on some of the tracks. But, I believe part of the problem is that so much of it was recorded in a house that in no way can handle her vocal instrument. Compared to "19", the recording does sound better.
    A good read on the recording process for this album: http://www.soundonsound.com/sos/sep11/articles/it-0911.htm
    I've listened to "21" many times now on my main rig rotating between the Verity Audio Finns and Maggie 1.6qr with custom Skiing Ninja x-overs. It's not great, but nor is it unlistenable by any measure.
    Hopefully, in the not too distant future we will be able to purchase a MoFi copy of "21" in its true glory.
    Former Staff Member TONEAudio
    2 Ch. System
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Wow is all I can add this tread.... I'm behind the 8 ball on this one, I wished to pick this CD up and now I'm afraid I'm not going to like this CD!
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • snow
    snow Posts: 4,358
    disneyjoe7 wrote: »
    I think you will enjoy it, sure the dynamics are a bit much at times but the music itself is worth having, no doubt one of the top 10 voices in the last few years.
    Here is a link that gives you an idea of what the CD sounds like, simply click on the arrow next to each song to listen to them.
    http://www.bing.com/music/songs/search?q=Adele&artistID=3C260D00-0600-11DB-89CA-0019B92A3933&FORM=DTPMUO
    REGARDS SNOW
  • steveinaz
    steveinaz Posts: 19,545
    There's nothing wrong with your equipment. It's compression. All the peaks have been chopped off due to everything being boosted to satisfy the "louder is better" crowd. I'd bet that cd doesn't have 8dB of dynamic range.
    For those of you not familiar with this "technique" go to youtube and search "loudness wars." You'll see how distorted and compressed some of you music is.
  • Serendipity
    steveinaz wrote: »
    Thanks. I guess there's nothing I can do except turn the music down, even at -32 it's too loud. And for those saying I would damage my gear, you guys are right - if I play one of my usual classical recordings at +4 and then switch to Adele I'd definitely be clipping my system and destroying a tweeter or more. Gotta remember to turn down the volume before switching over.
    Otherwise, boom --> empty wallet --> replace tweeters.
  • steveinaz
    Luckily for me, 75% of my CD's were bought in the early/mid 80's, before they started jacking everything up to satisfy the boom-box crowd. Now, before I buy any CD---I research it first. I'm still in the process of going back and finding better "masters" of some of my collection. I'm also getting rid of all "greatest hits" compilations and buying the seperate albums.
  • Serendipity
    steveinaz wrote: »
    I find sometimes, the remasters actually sound worse than the original recordings. For example, one day my father brought home "ABBA's Greatest Hits" and it was noisy and distorted. Had the same problem as the Adele recording, couldn't turn it up to 0dB. Some of U2's remasters also sound noticeably louder and have more clipping distortion than the original recordings.
    Fortunately, 90% of my music collection is not pop/rock/hip-hop, for example you can still buy good Jazz recordings that can be turned up and not get listener fatigue. Lots of my Classical CDs from the 80s also sound really good.
    tonyb Posts: 33,068
    steveinaz wrote: »
    Absolutely......but also, playing that compressed crap at Higher SPL's.....not good.
    Question for you cd rippers. When you guys rip a cd, do you rip the whole thing, every song, first and then take out what you don't want....or....do you take out the songs you don't want before ripping the cd ? Does it make a difference in the quality of the outcome ? Just curious is all.
  • steveinaz
    Yep; because many so-called "remasters" are nothing more than re-recordings with jacked-up levels. I don't buy any remasters without researching them first. Now, the LATEST ABBA remasters are suppose to be very well done.
  • steveinaz
    tonyb wrote: »
    I rip the entire CD, I don't see how it would have any effect on SQ using either method you describe for removing unwanted songs.
  • Serendipity
    tonyb wrote: »
    Absolutely right. The AVR-5800 is rated at 170W/ch in stereo mode, magazines have rated it at around 146W/ch, so figure it produces about 128W/ch in 2 channel mode. For every doubling of the wattage you increase the SPL by 3dB, so I have approximately a 21dB gain before I hit clipping.
    Problem is, I have found that there is more than a 21dB difference between the Adele recording vs. my classical recordings. More like around a 30dB difference in the level.
    My speakers have around a 90dB sensitivity. At +4 with a crappy, compressed recording I'd be in the 110-120dB range. Yeah, expect some tweeters and woofers to fry at that level.
    Not good.
  • Serendipity
    At a setting of 0 I have already determined that my in-room SPL's are around 77dB with one of my typical recordings.
    I get roughly the same in-room SPL at -30 with a loud, compressed recording.
    So for all reading this thread, BE CAREFUL with the volume knob on a dangerous recording like this one. I can clip my system without even getting to 0 on this one!!
  • drumminman
    drumminman Posts: 3,396
    Just got "21" this past weekend. Her voice does sound a bit strident on some passages, more the first 2-3 tracks than the later ones. She's hitting the notes, but it sounds to me like she's over driving the mic, or the recording levels are turned up too high. The compression is pretty bad too.
    Aside from the recording quality, the music is very good! I'd say it's one of those CD's that you have to try to listen past the limitations to the music.
    tonyb Posts: 33,068
    drumminman wrote: »
    If I have to try that hard, it isn't worth it. Just my .02
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I say play 21 on some tubes and you wont notice anything wrong with the recording :twisted:
  • steveinaz
    You'd need tubes the size of a nuclear reactor to fix this mess. Tubes do nothing for severe compression. Her voice sounds good, it's the band/music that is pushd into the stratosphere. Much the same as Daughtry's first album; clear vocals...then NOISE,. What a shame for such an excellent effort.
  • Serendipity
    drumminman wrote: »
    How can you listen past the limitations of the music if it is fatiguing to listen to?
  • Serendipity
    steveinaz wrote: »
    I'm glad that I'm not the only one that feels this way.
    See here:
    http://therealkfish.com/2011/03/10/a-letter-to-rick-rubin/
  • Serendipity
    More like a band-aid to try and fix the problem.
  • sucks2beme
    sucks2beme Posts: 5,681
    A most of pop music is like this. The industry is all about compression.
    I heard David Lee Roth commenting about how modern Country has gotten
    and talked of compression like it was a good thing! Even Norah Jones' last album
    was was too hot with the levels. It really ruined it for me.
  • steveinaz
    Hopefully Country music won't fall victim, they typically do a really nice job of mastering.
  • snow
    snow Posts: 4,358
    The only solution to this problem is to karma it off :mrgreen:
    REGARDS SNOW
    heiney9 Posts: 25,421
    The last Norah Jone's cd is a horrible recording, simply horrible. Worse than 21.
  • newbie308
    newbie308 Posts: 800
    If you think the quality of the CD is poor, you should hear/see the vinyl! I had to return the record 3 times due to bad pressings. The first record had a bubble that formed a hole clear through the first track. The second record was an incomplete pressing and shaped like an oval. The third record was flattened at one point so the tracks faded to nothing like someone melted and mashed it. Fortunately Amazon was cooperative with the whole mess, but I think the factory needs to buy some inspection equipment from my company!
