Anybody Who Does Woodworking, Comments on Kreg
[Deleted User]
To anybody who has done any woodworking, have you seen or tried out the Kreg woodjoining jig ? If so, interested for comments because I was thinking of getting one. Thanks. :cool:
I have one. Pretty simple to use.Panny 8000 project
Oppo 103D
Fronts- Monitor 70's
Upper fronts- Monitor 30's
Surrounds- Monitor 50's
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up] -
I have one. I like it. I use it to make mirror frames and to join the miter's for stair nosings.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
I'm in the same boat, thinking of getting one. About to construct some living room built ins. If you do a google search and find a site that sells them they usually have a video posted on how to use them. It looks really easy and effective."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I've been using pocket hole joints for years, and they work really well and the Kreg jigs and accessories make it easy to do.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Sounds like a plan then. I'll probably build some media storage to start with. Thanks. :cool:
Good luck with your projectPanny 8000 project
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
My father in law has a different Kreg jig and is very happy with it.
Excellent tool. I much prefer using this to a biscuit joiner or dowels. Makes good and strong joints. I also like that since it is a screw if a couple pieces have warped a bit you can pull them into place pretty easily. I bought one 2 years ago and use it on most of my wood projects.
Find a place to buy the screws cheap. After the initial purchase that is where the cost is as you have to buy a certain length and perhaps type for the material you are using.
Have fun with the project,
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
