Anybody Who Does Woodworking, Comments on Kreg
[Deleted User]
[Deleted User] Posts: 1,225
edited February 2012 in The Clubhouse
To anybody who has done any woodworking, have you seen or tried out the Kreg woodjoining jig ? If so, interested for comments because I was thinking of getting one. Thanks. :cool:
  • woodhead 2
    woodhead 2 Posts: 367
    I have one. Pretty simple to use.
    Panny 8000 project
    Oppo 103D
    Fronts- Monitor 70's
    Upper fronts- Monitor 30's
    Surrounds- Monitor 50's
    Backs- Monitor 40's
    Center-CS 350
    Sub- SVS PB 2000
    Onkyo 607[back up]
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    I have one. I like it. I use it to make mirror frames and to join the miter's for stair nosings.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • drumminman
    drumminman Posts: 3,396
    nap wrote: »
    I'm in the same boat, thinking of getting one. About to construct some living room built ins. If you do a google search and find a site that sells them they usually have a video posted on how to use them. It looks really easy and effective.
  • dkg999
    dkg999 Posts: 5,647
    I've been using pocket hole joints for years, and they work really well and the Kreg jigs and accessories make it easy to do.
    DKG999
  • [Deleted User]
    Sounds like a plan then. I'll probably build some media storage to start with. Thanks. :cool:
  • woodhead 2
    Good luck with your project
    Panny 8000 project
    Oppo 103D
    Backs- Monitor 40's
    Center-CS 350
    Sub- SVS PB 2000
    Onkyo 607[back up]
  • Shizelbs
    Shizelbs Posts: 7,433
    My father in law has a different Kreg jig and is very happy with it.
  • Gadabout
    Gadabout Posts: 1,072
    Excellent tool. I much prefer using this to a biscuit joiner or dowels. Makes good and strong joints. I also like that since it is a screw if a couple pieces have warped a bit you can pull them into place pretty easily. I bought one 2 years ago and use it on most of my wood projects.
    Find a place to buy the screws cheap. After the initial purchase that is where the cost is as you have to buy a certain length and perhaps type for the material you are using.
    Have fun with the project,
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
