IHT 6000 Subwoofer Issue
Nmesseng
Nmesseng Posts: 3
edited March 2012 in Troubleshooting
My subwoofer stopped producing any sounds 3 days ago. I have used the system for 6 months now. Just stopped working. Green light stays illuminated on back when soundbar is on so i think it is connected. I have synced it multiple times in the past few days and still no sound. No new electronics in the house. Could it be a blown fuse inside the subwoofer?
Post edited by Nmesseng on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited February 2012
    Hello,
    Thanks for posting on Polk's forum, I'm sorry you're having a problem. If the green LED is on I doubt the problem is related to the AC fuse. How have you connected the SB6000 to the rest of your system? What program material are you using to determine there's nothing coming from the sub?
    Regards, Ken
  • Nmesseng
    Nmesseng Posts: 3
    I have used various sources connected to any of the three inputs on the back of the sound bar. The sound bar itself plays fine but there is nothin coming out of the sub.
  • Nmesseng
    Nmesseng Posts: 3
    My neighbor in the apartment next door just got a belkin aircast bluetooth receiver. He even turned that off for me to see if it would help (i live in an apartment). It did not fix the problem either.
  • [Deleted User]
    Hello,
    It would be best to contact Polk's CS either by phone at 1-800-377-7655 or via email at polkcs@polkaudio.com. They'll help you get things sorted out.
    Regards, Ken
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2012
    Did you ever get this working? Polk CS should set you straight. Looks like interference is not an issue based on what you are telling us. Give them a call, their customer service is top notch.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
