DIY Jumpers...
Bump, for those who missed it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Those look real purty Steve. Did you notice an improvement?
What I did:
First off, I'm a bare wire kinda guy so this was easy. I measured between the terminals, added an extra 1/2 inch and cut the insulation. I then slid the insulation up about 1/2 inch and then stripped the ends as normal. I wrapped the 1/2 inch gap around the bottom post and connected the top as normal. Basically I removed the jumper and connected the wire to both terminals. It made for a very good improvement over the stock jumpers. I'd post a pic, but I'm not currently using this wire or speakers.Make it Funky!
Gidrah...err ski..
Back when I had bi-wirable speakers, they were better than the brass jumping bar provided, definitely. I don't have to sweat that anymore....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
G-MO: those are VERY purty.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
do you use spades for the main conectors? or are they bananas?
steveinaz, thanks, I think they turned out well.
goingganzo, I use spades to connect the amp to the bottom set of terminals. You can't use 2 sets of bananers on one set of nuts. If you look close at my first pic, you can see they are Monster Cable's Quik Lok spades, on the bottom nuts.Bob Mayo, on the keyboards. Bob Mayo. -
Same here, spades on my AQ Granites.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
