DIY Jumpers...
steveinaz
steveinaz Posts: 19,547
edited April 2004 in Speakers
  • steveinaz
    edited April 2004
    Bump, for those who missed it.
  • gidrah
    gidrah Posts: 3,050
    edited April 2004
    Those look real purty Steve. Did you notice an improvement?
    What I did:
    First off, I'm a bare wire kinda guy so this was easy. I measured between the terminals, added an extra 1/2 inch and cut the insulation. I then slid the insulation up about 1/2 inch and then stripped the ends as normal. I wrapped the 1/2 inch gap around the bottom post and connected the top as normal. Basically I removed the jumper and connected the wire to both terminals. It made for a very good improvement over the stock jumpers. I'd post a pic, but I'm not currently using this wire or speakers.
    Make it Funky! :)
  • gmorris
    gmorris Posts: 1,179
    edited April 2004
    Here are mine...
    Bob Mayo, on the keyboards. Bob Mayo.
  • gmorris
    edited April 2004
    one more pic..
  • steveinaz
    edited April 2004
    Gidrah...err ski..
    Back when I had bi-wirable speakers, they were better than the brass jumping bar provided, definitely. I don't have to sweat that anymore....
  • steveinaz
    edited April 2004
    G-MO: those are VERY purty.
  • goingganzo
    goingganzo Posts: 2,793
    edited April 2004
    do you use spades for the main conectors? or are they bananas?
  • gmorris
    edited April 2004
    steveinaz, thanks, I think they turned out well.
    goingganzo, I use spades to connect the amp to the bottom set of terminals. You can't use 2 sets of bananers on one set of nuts. If you look close at my first pic, you can see they are Monster Cable's Quik Lok spades, on the bottom nuts.
  • steveinaz
    edited April 2004
    Same here, spades on my AQ Granites.
