Ugh! Rti70's!
codyc1ark
codyc1ark Posts: 2,539
edited February 2012 in The Clubhouse
Just picked up a pair of rti70s, dropped em' in and both have blown tweeters. Thankfully I don't have much in them, and what reading tells me they most likely aren't worth fixing. You guys know if the is any interest in the woofers or baffles? Stinks buying a pair of speaks when you can't hear em first.
Post edited by codyc1ark on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Make sure you have the brass connection jumpers on the binding posts.
  • codyc1ark
    I had already checked and double checked. :mad:
  • kuntasensei
    kuntasensei Posts: 3,263
    Wow, that sucks. I'm running RTi70s and I like the way they sound. Why do you think they aren't worth fixing?
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    That RTi series wasn't a very liked generation in the RT line. I had the 70s for a couple years and they were fine with me, but there were generations before and after that sounded better.
    That being said, why not see if you can get some replacement tweeters for cheap and see how you like them?
  • codyc1ark
    Most ofthe reviews said what your saying. I'm going to call into Polk Monday or Tuesday and see what a replacement pair is. I would like to hear them, just to get my ears on another pair of polks.
    VR3 Posts: 29,697
    The RTi70 line lasted a little over a year where as most Polk lines last 3-5-10 years...
  • dkg999
    dkg999 Posts: 5,647
    I have a second HT system that has my old RTi70's, a CSi40, and a pair of RTi38's. It sounds really nice and the RTi70's dig deep enough that it works well without a sub. Not a speaker I would use for a music only system, but for HT they work fine.
    DKG999
  • codyc1ark
    DSkip wrote: »
    Polk has no replacements in stock. I've been trying to track down replacements for my 3000p's for quite a while now.
    I had read that there was an alternate tweeter that fits from Polk, any idea on that one? Seems like I'll have to part the drivers out and perhaps find a home for the cabs if anyone needs them.
    VR3 Posts: 29,697
    The RT3000p tweeter (the tri lam) was discontinued when the RTi70 series came out (silk tweeter) -
    There for a while they were interchangeable so I am guessing the RTi70 tweeter is discontinued?
    Looks like EBay is your best bet... Just remember those tweeters snap into the baffle, no screw holes
  • seeclear
    seeclear Posts: 1,244
    Probably an obvious suggestion, but did you check the drivers to make sure it was the tweeter and not the crossover?
    crossover components would be easier to source than the tweeter.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • codyc1ark
    I have not checked the xovers, however just got off the phone with CS and they stated there has been two different tweeters avail, but nothing in stock. I don't think they support this line anymore. So, back to square one, whatever that is.
  • rooftop59
    rooftop59 Posts: 8,120
    I have bought used speakers before, hooked em up and the tweeter doesn't work. Open them up and low and behold the wired connecting the tweeter had come unplugged. On one pair of older polk (rt3s I believe) there was no sound coming from the woofer of one speaker and no sound coming from the tweeter of the other. Opened them both up and both had disconnected from the crossover, easy fix. Took about 10 minutes. Definitely worth a try.
    Game Room 5.1.4:
    Bedroom 2.1
  • codyc1ark
    Alright, check it. I think I have a blowen cap on my crossover, what do you guys think?
  • Tbone289
    Tbone289 Posts: 661
    Take a look at the RTi70 schematic here. You will see that the 7.5uf cap (C1) that is blown in your crossover is indeed in the tweeter circuit. It's definitely worth it to try replacing it, as the cap will be inexpensive. However, just replacing the cap won't ensure that there aren't other components in that circuit that are faulty. Do you have a DMM that you could use to test the other components in the tweeter circuit?
    ...I would probably try replacing the cap anyway if I were you.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • codyc1ark
    Tbone289 wrote: »
    I do have a DMM. For the going rate on these speakers, I'm think I may cut my losses and part them out. Although, if anyone semi-local to western NC wanted the pair, I could cut a very, very good deal as a project speaker....
  • ViperZ
    ViperZ Posts: 2,046
    codyc1ark wrote: »
    You're going to part out a pair of speakers because you need to replace two 10-cent capacitors??? Holy moly.. Good luck!
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
