Caig products
ezc
ezc Posts: 426
PJ & Doro thanks for the tip on Caig products. Found a dealer here & got deoxit & pro gold in spray cans. I wanted non aresol but thats all they had. I stripped my dvd player last night took out the main boards, power cord, & others. Used the deoxit on the female rca's & all contacts. My rca had some corrosion that the alc. couldnt remove and other rcas that never was used had lots of junk on them. The deoxit cleaned them up real nice & with very little work. Cleaned the power cord ac prongs & the opposite side that plugged into the board, Cleaned the contacts on the boards too & that also cleaned up great. Finished with pro gold & put everything back together. Pulled out all the interconnects, dig coax cable & component cable, clenaed with deoxit & treated with progold. I cant say the pic quality got better but I do think the sound when playing through IC sound better. Seems like the soundstage got deeper & threre are more layers of music ( more detail) Im not a big busic listener but Im almost sure is sounds better. My wife will be able to tell, she listens much more than I do.I got to try the flashlight test, like the one on the caig site. I have a single aaa light I use on my bench & the batt was about 80-90% dead & the light was dim. as per the site I sprayd the contacts the switch & batt - & + waited 2 min & put it back together. Turned it on & off a few times to clean the switch & was supprised the light was much brighter! Somthing worked! Now its time to clean, clean , clean oh what fun:eek:
Post edited by ezc on
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    You are very welcome ezc. I purchased a small vial of the Pro Gold myself to treat some of the DIY wires I'm making.
    Man, we've all heard the term "snake oil" before and that is what I jokingly think to myself when I am using it on some of the newer stuff I'm working on. Looks like the Detoxit did help you with some cleaning and that is great. I guess long term observations will dictate if the ProGold really helps to minimize contamination. People swear by the stuff though.
  • dorokusai
    dorokusai Posts: 25,633
    edited April 2004
    Ace - Glad the suggestion was useful, it's nice stuff. Nothing like shiny new gold RCA's :D
  • ezc
    ezc Posts: 426
    edited April 2004
    Ive been using the deoxit & progold for about 4 days now & damm it works! Were Nokias repair center here in Hawaii & I see liquad damaged phones daily. water , soda, beer on & on. I have tried many many chemicals to clean corrosion & oxidation from phone contacts. I was using some military electronic cleaning soultion that a customer gave me & that was better than any other cleaners I have used. But after using the deoxit I was amased the Deoxit did a better job & I didnt have to scrub at the contacts as much ( much less preasure). As I clean my system Ill use the deoxit to clean & progold to treat. Clean connectors & contacts----Better Picture--- Better Sound! Thanks for the Tip!!!!!
  • gacole2000
    gacole2000 Posts: 255
    edited April 2004
    Where do you get this "snake oil"?
    Thanks- Greg:)
    AVR: Yamaha RX-V661
    DVD: Yamaha DV-C6480
    BR: Samsung 1600
    Mains: Polk RT55 (bi-amped)
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
    Projector: Optoma HD70 w/ 106" Elite Screen
    Power: Panamax MAX 5100
    Remote: Harmony One
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2004
    More later,
    Tour...
    Vox Copuli
  • ezc
    ezc Posts: 426
    edited April 2004
