Opitcal cable
rwanders
rwanders Posts: 2
edited February 2012 in Troubleshooting
Just hooked up my surroundbar 4000 and have a problem with the supplied opitcal cable being very loose and coming out. during use. This is the jack on the sound bar only.
The jack on my Samsung led tv fits the plug very snug.
Tried reversing the ends and it still occers on the soundbar end.
Apart from returning it for another, what does anyone suggest?
Also would Toslink optical cables be a noticable improvement over those supplied?
Post edited by rwanders on
  • shawn474
    shawn474 Posts: 3,052
    edited January 2012
    i had a problem with my new television and the optical cable being loose. To be honest, I just wasn't pushing it in hard enough. I applied some force and it snapped in. Hasn't given me a problem since. Not sure if thats your problem but may want to try it. There is a lip on a lot of the optical cables and when they are new it takes a bit of pressure to snap them into place.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • rwanders
    rwanders Posts: 2
    edited January 2012
    Thanks!
    I will give it a try.
  • Serendipity
    Serendipity Posts: 6,975
    I would recommend using a different optical cable. Some fit better than others.
    For example, my Denon AVR-5800 works best with high-end optical cables (such as my Straight Wire Optical), but a cheaper Monster cable keeps falling out.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • shawn474
    http://www.amazon.com/gp/product/B004GVLM2E/ref=oh_o04_s00_i00_details
    I got this one and I thought there was something wrong with my AVR port or with the cable itself. However, with a little pressure this "snapped" in and holds tighter than any other optical cable I have owned. The Monoprice ones are nice, but they would fall out consistently with my gear.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
