Sub cable recommendations for Micropro 4000
blueboxer
Currently running just a monster RCA cable, but was hoping to go with a more mid-level or higher cable to maximize performance. Was looking at perhaps the Audioquest Type-X or signalcable for more budget minded cable. Anyone with experience with whether or not a quality cable is worth it for subs, I would appreciate any feedback you can offer.
Post edited by blueboxer on
I'm no expert but I've tried about 5 or 6 different cables with my subs and couldn't tell a difference. Not worth it IMO.
Signal it is, thanks Leroy!
How are you liking the 4000?
I bought my 8ft pair from Blue jeans, Belden.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Here's the beldens I bought (LC-1), very nice: http://www.bluejeanscable.com/store/subwoofer/index.htmSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
I've used RG-6 cable and compression fittings with RCA ends. I've also used RG-6 with standard cable F-connectors and used F to RCA connectors at the ends. Monoprice has them: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10430&cs_id=1043008&p_id=4130&seq=1&format=2
Never a problem, and they are cheap.My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 705 rears
Polk RC-80i x 4 In Ceiling Atmos speakers
2 x SVS PB12/Plus 2's
Denon X3700H
Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2000/NX7 projector
Silver Ticket 120" acoustically transparent screen
Berkline 090 electric recliners with Aura Bass Shakers -
for the sub setup. i agree 150%
i tried monoprice, blue jeans, audioquest sidewinders,audioquest king cobra and MIT AVT3. they all sounded the same to me. have monoprice hooked up now.mole' -
No need for boutique cables on a sub.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
