"Veneer" on MDF - tips?
mdaudioguy
I put together some MDF cabinets to remake my Heresy II speakers. I'm thinking of covering them with... Formica! I wanted to do something a little different. Good idea or not? Anyone done anything similar or otherwise creative?
Contact cement world work best."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Google "Colorcore" by Formica.( no dark/different colored edges)
IMO if you're going to go through all the work of putting veneers on a cabinet, may as well use real wood veneers. You can buy sheets of the stuff online.
Monster AVL-300, HTS-2500 MKII -
wow, very interesting idea!
I'm doing wood veneer eventually, but this would be something to consider. Is there marble, or granite formica that you could do speakers? I might consider making a housing for my outdoor speakers. Hmm.....Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- Monitor Audio Silver rx2, , surround backNHTsuper1's surround, Parasound 1500, Marantz 2230/Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe -
Just in case you are unfamiliar with wood veneers, you can get them backed with paper or peel-and-stick adhesive, so the procedure for installing them wouldn't be that much different from installing plastic laminate (Formica). So it's not really a matter of one being easier than the other--the main difference is simply the cost of the material.
I have plenty of wood speakers. I don't want wood. I want something different.IMO if you're going to go through all the work of putting veneers on a cabinet, may as well use real wood veneers. You can buy sheets of the stuff online.
Anyhow, this is just for the fun of it. Besides, I already own a spare 4x8 sheet of Formica. -
^^ Thank you for that link - very helpful.
Just DO NOT use the trimmer bit shown, instead, get the ones with a ball bearing guide. The real art to laminate work is the filing of the edges. (and not getting crud under the laminate and causing a bump to show on the surface)
Yes, I was looking at both kinds today at Lowe's and bought one with a bearing. It just seemed like a better idea. I cut the laminate today, and plan to start gluing tomorrow evening.Just DO NOT use the trimmer bit shown, instead, get the ones with a ball bearing guide. The real art to laminate work is the filing of the edg es. (and not getting crud under the laminate and causing a bump to show on the surface) -
A few pics of what I've done so far...
I think I just invented myself a speaker that I can set my drink on and not have to worry about it! :cheesygrin:
Next I need to cut the pieces for the front edge. -
Those pictures make them look small."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
They really aren't very big overall, considering they house a 12" woofer. Only about 21" tall.Those pictures make them look small. -
Cool. I like the creative approach. I'd sorta like to see how a lighter fabric would look. Maybe a smooth-textured cream or sand color found in the Formica.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Looks much better than I expected. Very cool!
That's exactly the same pattern on my 70's mancave bar. Wicked.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I'm pleased enough with the results... not quite perfect, IMO, but I definitely learned from the project. It also has me thinking of a future DIY project...
nice job, very creative2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Nice finish!Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
