"Veneer" on MDF - tips?
mdaudioguy
mdaudioguy Posts: 5,164
edited January 2012 in DIY, Mods & Tweaks
I put together some MDF cabinets to remake my Heresy II speakers. I'm thinking of covering them with... Formica! I wanted to do something a little different. Good idea or not? Anyone done anything similar or otherwise creative?
  • Face
    Face Posts: 14,340
    edited January 2012
    Contact cement world work best.
  • gdb
    gdb Posts: 6,012
    edited January 2012
    Google "Colorcore" by Formica.( no dark/different colored edges):wink:
  • Syndil
    Syndil Posts: 1,582
    edited January 2012
    IMO if you're going to go through all the work of putting veneers on a cabinet, may as well use real wood veneers. You can buy sheets of the stuff online.
  • evhudsons
    evhudsons Posts: 1,182
    edited January 2012
    wow, very interesting idea!
    I'm doing wood veneer eventually, but this would be something to consider. Is there marble, or granite formica that you could do speakers? I might consider making a housing for my outdoor speakers. Hmm.....
    Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- Monitor Audio Silver rx2, , surround backNHTsuper1's surround, Parasound 1500, Marantz 2230/Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
  • Syndil
    Syndil Posts: 1,582
    edited January 2012
    Just in case you are unfamiliar with wood veneers, you can get them backed with paper or peel-and-stick adhesive, so the procedure for installing them wouldn't be that much different from installing plastic laminate (Formica). So it's not really a matter of one being easier than the other--the main difference is simply the cost of the material.
  • mdaudioguy
    edited January 2012
    Syndil wrote: »
    I have plenty of wood speakers. I don't want wood. I want something different.
    Anyhow, this is just for the fun of it. Besides, I already own a spare 4x8 sheet of Formica.
  • Face
    Face Posts: 14,340
    edited January 2012
  • mdaudioguy
    edited January 2012
    ^^ Thank you for that link - very helpful.
  • gdb
    gdb Posts: 6,012
    edited January 2012
    Just DO NOT use the trimmer bit shown, instead, get the ones with a ball bearing guide. The real art to laminate work is the filing of the edges. (and not getting crud under the laminate and causing a bump to show on the surface)
  • mdaudioguy
    edited January 2012
    gdb wrote: »
    Just DO NOT use the trimmer bit shown, instead, get the ones with a ball bearing guide. The real art to laminate work is the filing of the edg es. (and not getting crud under the laminate and causing a bump to show on the surface)
    Yes, I was looking at both kinds today at Lowe's and bought one with a bearing. It just seemed like a better idea. I cut the laminate today, and plan to start gluing tomorrow evening.
  • mdaudioguy
    edited January 2012
    A few pics of what I've done so far...
    I think I just invented myself a speaker that I can set my drink on and not have to worry about it! :cheesygrin:
    Next I need to cut the pieces for the front edge.
  • Face
    Face Posts: 14,340
    edited January 2012
    Those pictures make them look small.
  • mdaudioguy
    edited January 2012
    Face wrote: »
    They really aren't very big overall, considering they house a 12" woofer. Only about 21" tall.
  • vcwatkins
    vcwatkins Posts: 1,992
    edited January 2012
    Cool. I like the creative approach. I'd sorta like to see how a lighter fabric would look. Maybe a smooth-textured cream or sand color found in the Formica.
  • Big Dawg
    Big Dawg Posts: 2,005
    edited January 2012
    Looks much better than I expected. Very cool!
  • steveinaz
    steveinaz Posts: 19,547
    edited January 2012
    That's exactly the same pattern on my 70's mancave bar. Wicked.
  • mdaudioguy
    edited January 2012
    I'm pleased enough with the results... not quite perfect, IMO, but I definitely learned from the project. It also has me thinking of a future DIY project...
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited January 2012
    nice job, very creative
  • vcwatkins
    edited January 2012
    Nice finish!
