Silicon Tube rings
brgman
brgman Posts: 2,859
edited January 2012 in DIY, Mods & Tweaks
I see people sell these for tubes on the net.Just so you know i stock a lot of sizes in our company so if you want them get the dimensions and i may be able to save you a few cents.
I’M OFFENDED!!!!
Post edited by brgman on
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2012
    brgman wrote: »
    I purchased a CJ-PV7 several years ago that had a small amount of melted rubber on the circuit board below one tube base.
    It hadn't hurt anything and was easily removed. The seller told me it was the remnants of a tube damper, but I have no idea if it was a simple neoprene ring, silicone ring or if the tube went up in flames or what.
    QUESTIONS: Are silicone rings able to withstand higher temperatures than simple neoprene rings? Do you know how high of a temperature silicone can withstand?
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Silicon handles higher temps.Regular about 200 deg and hi temp silicon about 245
    then you can get into kalrez which is good to about 600 deg but i don't know if that would be a dampening material.Different consistency stuff.
    I’M OFFENDED!!!!
  • quadzilla
    quadzilla Posts: 1,543
    edited January 2012
    Probably sorbothane. CJ has a warning on their site against using those due to melting issues. I've got a call into them to see what dampers they recommend.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • inspiredsports
    edited January 2012
    quadzilla wrote: »
    I've been using Herbie's for about 3 years now and they are very, very good, but also comparatively expensive.
    I'd love to try this economical alternative if possible.
    NAD SS rigs w/mods
    GIK panels
  • musky1963
    musky1963 Posts: 275
    edited January 2012
    I would think that 12ax7's would be a popular choice. Got a ballpark on those?
    Jeff
  • brgman
    brgman Posts: 2,859
    edited January 2012
    musky1963 wrote: »
    what's the outside dimension of the tube where the ring would sit?
    I’M OFFENDED!!!!
  • musky1963
    edited January 2012
    On a GE I just grabbed, I got approx. 13/16"-7/8".
    Jeff
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Based on the 7/8 ID here is info from our company website.These are good to 450 degrees too.
    Teflon may also be available.I'll check.
    Part#: 06 316
    Item#: 9451853
    Manufacturer: O-Rings
    Oring
    Weight: 0.008 lbs.
    Product Name: Individual O-Rings
    Description: 7/8" ID; 1 1/4" OD; 3/16" Cross Section Diameter; Silicone; 70 Durometer; O-Ring
    Shopping
    Price: $1.20
    Qty Sensitive Pricing: Details
    Total Available: Contact Local Service Center
    Order Qty:
    Add
    You may also need: O-Ring Tools
    Find Similar Part i
    Specifications
    Inside Dia. [Min] Inside Dia. [Max]
    Inside Dia. 7/8 in Outside Dia. [Min]
    Outside Dia. [Max] Outside Dia. 1 1/4 in
    Cross Section Dia. 3/16 in Material Silicone
    Durometer 70 Temperature Range [Min] -80 ?F
    Temperature Range [Max] 450 ?F
    I’M OFFENDED!!!!
  • musky1963
    edited January 2012
    Now I need to get some tube gear again. Sold all mine.
    Jeff
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Here's Teflon-a little softer durometer but you wouldn't notice by feel probably.
    Part#: 17 316
    Item#: 9451429
    Oring
    Weight: 0.009 lbs.
    Description: 7/8" ID; 1 1/4" OD; 3/16" Cross Section Diameter; Teflon?; 55-65-D Durometer; O-Ring
    Shopping
    Price: $3.24
    Order Qty:
    Add
    Find Similar Part i
    Specifications
    Cross Section Dia. 3/16 in Material Teflon?
    Durometer 55-65-D Temperature Range [Min] -65 ?F
    Temperature Range [Max] 500 ?F
    I’M OFFENDED!!!!
