Silicon Tube rings
brgman
I see people sell these for tubes on the net.Just so you know i stock a lot of sizes in our company so if you want them get the dimensions and i may be able to save you a few cents.
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
I purchased a CJ-PV7 several years ago that had a small amount of melted rubber on the circuit board below one tube base.
It hadn't hurt anything and was easily removed. The seller told me it was the remnants of a tube damper, but I have no idea if it was a simple neoprene ring, silicone ring or if the tube went up in flames or what.
QUESTIONS: Are silicone rings able to withstand higher temperatures than simple neoprene rings? Do you know how high of a temperature silicone can withstand?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Silicon handles higher temps.Regular about 200 deg and hi temp silicon about 245
then you can get into kalrez which is good to about 600 deg but i don't know if that would be a dampening material.Different consistency stuff.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
inspiredsports wrote: »I purchased a CJ-PV7 several years ago that had a small amount of melted rubber on the circuit board below one tube base.
Probably sorbothane. CJ has a warning on their site against using those due to melting issues. I've got a call into them to see what dampers they recommend.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I've been using Herbie's for about 3 years now and they are very, very good, but also comparatively expensive.
I'd love to try this economical alternative if possible.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
I would think that 12ax7's would be a popular choice. Got a ballpark on those?Jeff
what's the outside dimension of the tube where the ring would sit?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Based on the 7/8 ID here is info from our company website.These are good to 450 degrees too.
Teflon may also be available.I'll check.
Part#: 06 316
Item#: 9451853
Manufacturer: O-Rings
Oring
Weight: 0.008 lbs.
Product Name: Individual O-Rings
Description: 7/8" ID; 1 1/4" OD; 3/16" Cross Section Diameter; Silicone; 70 Durometer; O-Ring
Shopping
Price: $1.20
Qty Sensitive Pricing: Details
Total Available: Contact Local Service Center
Order Qty:
Add
You may also need: O-Ring Tools
Find Similar Part i
Specifications
Inside Dia. [Min] Inside Dia. [Max]
Inside Dia. 7/8 in Outside Dia. [Min]
Outside Dia. [Max] Outside Dia. 1 1/4 in
Cross Section Dia. 3/16 in Material Silicone
Durometer 70 Temperature Range [Min] -80 ?F
Temperature Range [Max] 450 ?FMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Here's Teflon-a little softer durometer but you wouldn't notice by feel probably.
Part#: 17 316
Item#: 9451429
Oring
Weight: 0.009 lbs.
Description: 7/8" ID; 1 1/4" OD; 3/16" Cross Section Diameter; Teflon?; 55-65-D Durometer; O-Ring
Shopping
Price: $3.24
Order Qty:
Add
Find Similar Part i
Specifications
Cross Section Dia. 3/16 in Material Teflon?
Durometer 55-65-D Temperature Range [Min] -65 ?F
Temperature Range [Max] 500 ?FMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!!
