Wiring a single LED into a 120v lamp assembly...
dorokusai
My wife wants to make a lamp using a cool tequila bottle and I want to wire a single LED from the socket into the base, to light up the interior. How is this done? I imagine I need a single wired LED with a small transformer to splice it into the circuit correct? Where do I buy this stuff?
It's a Milagro bottle, if anyone has had that brand. It's blown glass with a Agave plant structure as part of the interior of the bottle. We made one for my Mom, just to see how it would look and it's really kinda cool, for being an ode to alcohol. We used a flourescent bulb and made it as earth conscious as possible.
http://www.milagrotequila.com/#/our_tequilas/milagro_select_barrel_reserve_reposado
Post edited by dorokusai on
If you're looking for the 'end-all, be-all' of electronics shopping, the only place I know of is YDI:
http://www.youdoitelectronics.com/products.html
Click on the LED's, and you'll have your pick of colors, and voltages. There's a phone number on this page, so, if you can't find it, or have questions, they should be able to answer it.
HOW you do it, is another question.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Could giving the forward voltage and current add a resistor with a diode in series to drop the line voltage.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
This circuit looks pretty simple:
http://freecircuitdiagrams4u.blogspot.com/2009/12/120v-ac-powered-led.html
You could also market this concept to college students with a couple of mods.Wristwatch--->Crisco -
Thought about fiber optics? You could put light in several areas.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
This is an easy one! you can adjust the brightness of led by changing value of resistor. the capacitor must be X1 or X2.Make it simple...Make it better!
