Wiring a single LED into a 120v lamp assembly...
dorokusai
dorokusai Posts: 25,640
edited January 2012 in The Clubhouse
My wife wants to make a lamp using a cool tequila bottle and I want to wire a single LED from the socket into the base, to light up the interior. How is this done? I imagine I need a single wired LED with a small transformer to splice it into the circuit correct? Where do I buy this stuff?
It's a Milagro bottle, if anyone has had that brand. It's blown glass with a Agave plant structure as part of the interior of the bottle. We made one for my Mom, just to see how it would look and it's really kinda cool, for being an ode to alcohol. We used a flourescent bulb and made it as earth conscious as possible.
http://www.milagrotequila.com/#/our_tequilas/milagro_select_barrel_reserve_reposado
Post edited by dorokusai on
  • obieone
    obieone Posts: 5,077
    edited January 2012
    If you're looking for the 'end-all, be-all' of electronics shopping, the only place I know of is YDI:
    http://www.youdoitelectronics.com/products.html
    Click on the LED's, and you'll have your pick of colors, and voltages. There's a phone number on this page, so, if you can't find it, or have questions, they should be able to answer it.
    HOW you do it, is another question.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2012
    Could giving the forward voltage and current add a resistor with a diode in series to drop the line voltage.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • strider
    strider Posts: 2,568
    edited January 2012
    This circuit looks pretty simple:
    http://freecircuitdiagrams4u.blogspot.com/2009/12/120v-ac-powered-led.html
    You could also market this concept to college students with a couple of mods.
    Wristwatch--->Crisco
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited January 2012
    Thought about fiber optics? You could put light in several areas.
  • lanchile
    lanchile Posts: 560
    edited January 2012
    This is an easy one! you can adjust the brightness of led by changing value of resistor. the capacitor must be X1 or X2.
    Make it simple...Make it better!
