CS2 Series II - Which console...
radar2000
radar2000 Posts: 5
edited January 2012 in Speakers
Hi everyone.
Has anyone found an entertainment console that fits the CS2 Series II center channel speaker?
I'm looking for a console that has that center shelf that will hold my CS2 Series II speaker.
All that I've found can only accommodate an 18" width center channel speaker.
Any suggestions or links would be appreciated.
Thanks.
Post edited by radar2000 on
  • Geoff4rfc
    Geoff4rfc Posts: 2,959
    edited January 2012
    What kind of budget are you working with? I picked this up from my local Costco around 5 hun or so, came with doors and three sets of door panels, glass, wood and acoustic fabric.
  • radar2000
    radar2000 Posts: 5
    edited January 2012
    Thanks for the response Geoff4rfc.
    I was looking for something along these lines...
    Costco's stands don't have a center wide enough for the CS2 Series II.
  • Glowrdr
    Glowrdr Posts: 1,103
    edited January 2012
    My next purchase is going to be from Salamander Design (google them) Think build-it yourself Ikea furniture meets good quality. I'm looking at the Double Quad and removing the center support.
    Only setback? It's like $1700 bucks with all the accessories I want.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • Geoff4rfc
    edited January 2012
    radar2000 wrote: »
    Actually, the stand I have was purchased from Costco and my center is a CS2 SII. I purchased the cabinet about three years ago, like most everything at Costco, it comes and goes and sometimes doesn't come around anymore.
    The manufacturer is Bayside Furnishings and the picture I provided is the Marino 66" TV console W/Swinging floater.
    It's a real nice piece of furniture, the ends open up for even more storage, enough room on each end to have three shelves of Bluray/DVD or what ever.
    It's huge, the TV you see is my 50" plasma.
  • radar2000
    radar2000 Posts: 5
    edited January 2012
    Thanks for the response.
    Would you mind providing the picture?
    Thanks.
    Geoff4rfc wrote: »
  • Glowrdr
    edited January 2012
    Maybe i'm overlooking something obviously simple - but I believe post 2 is his picture that he's quoted on a few times...
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    edited January 2012
    While that cabinet in post 2 looks sweet, it appears to be missing some good ventilation. Maybe it's hidden behind the gear, but if your looking to adding amps or other warmer running gear, ventilation should be a top priority.
  • Geoff4rfc
    edited January 2012
    That's a good point Tony, hence the removal of the doors. The rear has four (two upper, two lower) cable routing vents measuring 12" x 2". While this is adequate for 5 thousand cables, it doesn't do much for overall ventilation.
    The front doors have three possible insets as mentioned in earlier post. For this set up, I chose the acoustic fabric so I could leave the doors closed during movie/music play, I also did audyssey with the speaker grill removed and the fabric door closed.
    The resulting sound was great and overall aesthetics were great, all my gear and center channel was hidden BUT, even with two fans I have inside, it wasn't quite enough to get the heat out, so off come the doors.
    Note the nice look with the doors (no, not Jim Morrison :-0)
  • Geoff4rfc
    edited January 2012
    Side storage; great for my 3yr old's library :cool:
