bought a used CSi30 - questions
young
young Posts: 22
edited April 2004 in Speakers
one of the bottom corners has a ding on it, maybe 1.5" long... slight split in the MDF. should i be concerned about that at all? is it just cosmetic?
it had been registered. is there a point in re-registering the speaker? is it even possible?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2004
    It shouldn't be an issue, as long as it isn't a hold all the way through, which is hard to imagine...
    No point in re-registering it, as the warranty isn't valid...but you should never need it...
  • dorokusai
    dorokusai Posts: 25,661
    edited April 2004
    You could touch up the crevice with wood epoxy/filler, and when it's dry, touch it up with a black "Sharpie".
  • young
    young Posts: 22
    edited April 2004
    thanks for the info, guys. yup, i have wood putty and some black paint so i'll fix it up. not a problem.
