bought a used CSi30 - questions
one of the bottom corners has a ding on it, maybe 1.5" long... slight split in the MDF. should i be concerned about that at all? is it just cosmetic?
it had been registered. is there a point in re-registering the speaker? is it even possible?
It shouldn't be an issue, as long as it isn't a hold all the way through, which is hard to imagine...Originally posted by young
No point in re-registering it, as the warranty isn't valid...but you should never need it... -
You could touch up the crevice with wood epoxy/filler, and when it's dry, touch it up with a black "Sharpie".CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
thanks for the info, guys. yup, i have wood putty and some black paint so i'll fix it up. not a problem.
