Subwoofer cable
JTodd
Hey guys! I am setting up a 5.1 system and the woman wants the sub in the back of the room out of sight. I am thinking of running the cable through the attic and down the wall to conceal the sub in the back of the room. Is there any reason this is a bad idea? Also where can I find 100+ ft of subwoofer cable? What is the difference between subwoorfer cable and speaker wire? I am new to building a system so... im kninda learning as I go. Thanks in advance for your help!!
Post edited by JTodd on
Id go under the floor if possible. Have you looked into the wireless subs? probably your better option there if possible.Too much **** to list....
Generally speaking, subwoofer cable is going to be a single RCA style cable instead of wire. That isn't always the case, but it's more than likely what you will have to deal with.
Is this a pre-existing system that you are just hooking up for someone? If not SDA's suggestion of getting a wireless sub is a great one. Check out Polks DSW wi line of subs (unsure of other makes with wireless capabilities)
Otherwise, depending on the layout of the room and the decor - you could always cover the sub and use it as a low "table" of sorts. I.E. cover it with some cloth, and put a plant or something on top of it. My Christmas tree stood on top of mine this year :redface:
Check out Monoprice.com for all your cable needs. This should at least get you pointed in the right direction. You'll be hard pressed to find a better price on cables anywhere else (especially that length)
$18 - http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=5872&seq=1&format=265" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Thanks for the replies! Is there any loss of quality of sound with a
Wireless sub? -
Outlaw sells a wireless module that you can use with pretty much anything.Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
