Subwoofer cable
JTodd
Hey guys! I am setting up a 5.1 system and the woman wants the sub in the back of the room out of sight. I am thinking of running the cable through the attic and down the wall to conceal the sub in the back of the room. Is there any reason this is a bad idea? Also where can I find 100+ ft of subwoofer cable? What is the difference between subwoorfer cable and speaker wire? I am new to building a system so... im kninda learning as I go. Thanks in advance for your help!!
Id go under the floor if possible. Have you looked into the wireless subs? probably your better option there if possible.Too much **** to list....
Generally speaking, subwoofer cable is going to be a single RCA style cable instead of wire. That isn't always the case, but it's more than likely what you will have to deal with.
Is this a pre-existing system that you are just hooking up for someone? If not SDA's suggestion of getting a wireless sub is a great one. Check out Polks DSW wi line of subs (unsure of other makes with wireless capabilities)
Otherwise, depending on the layout of the room and the decor - you could always cover the sub and use it as a low "table" of sorts. I.E. cover it with some cloth, and put a plant or something on top of it. My Christmas tree stood on top of mine this year :redface:
Check out Monoprice.com for all your cable needs. This should at least get you pointed in the right direction. You'll be hard pressed to find a better price on cables anywhere else (especially that length)
$18 - http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=5872&seq=1&format=265" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Thanks for the replies! Is there any loss of quality of sound with a
Wireless sub? -
Outlaw sells a wireless module that you can use with pretty much anything.Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
