Spikes - they really are that good!
lol!!!
I was serious, along with getting that TFL AI Cabinet. :cheesygrin:
BTW - I hope to get your tweeter brackets in my speakers by the end of this month.Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart. -
By the way - in case I wanted to drop by for a visit - where is Hell TFL? I can't get it to come up on my Garmin Nuvi or on Yahoo maps.Statistics show that 98% of us will die at some point in our lifetime.
Welcome, phoppman...I spiked my SDA 2bs ..... Great improvement in bass! The 2bs have a hollow box frame on their speaker's base - I used a couple aluminum angle brackets (as long as the box frame) that I attached to the frame with through bolts, and then the two spikes were mounted to the horizontal section of each bracket. A MUST DO tweak!
On carpet... yes?
I assume the Al brackets are plenty stiff, but regardless depending on how you oriented them I could see some potential of them "ringing".
Pics?More later,
Tour...
Vox Copuli
Thanks again Tour2ma! I once again have nice pressure rather than noise coming from my subs, and they sound much better blended for music. I had to research quite a bit on those Crankensteins. It's a funny brand name, and they are out of business but they certainly made my subs well.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- Monitor Audio Silver rx2, , surround backNHTsuper1's surround, Parasound 1500, Marantz 2230/Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
Finally,
got it perfectly set, thanks a bazillion! I finally got that feel the bass rather than hear the bass setting back again, and now even better.
Now I can listen at low levels even and get full bass through the air and it blends very very nice with my sda's. I put in Star Wars II to check it with the intro scene, awesome! But for music it's really now I perfect blend.
thanks again for the explanations and advice! PricelessPolk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- Monitor Audio Silver rx2, , surround backNHTsuper1's surround, Parasound 1500, Marantz 2230/Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe -
I was looking at spikes on parts express site this morning. Will they help on a tile floor? That system has a set of Klip Forte II's
for my 2b's, i have the dayton spikes right to the tile - no discs...they don't scratch either...2b's are light compared to others and not all tile is created equal, so YMMV....sound-wise? one of the best mods i've done
Welcome Texun2... all the best members have numerals in their screen name (especially "2", right, Mike?)... so the pressures on... :cheesygrin:
The reason to spike is universal... bedrock speaker stability. Spikes are a cheap enough tweak that there's no reason not to try them.More later,
Tour...
Vox Copuli
DANG! I knew I should have been audio_alan2. haha
I've been slacking and still need to order spikes. For the original large SDA-SRS's (pre-1.2's, but same form-factor), are these sufficient?
http://meniscusaudio.com/extra-points-p-1292.html
Or do I need to step up to the Ultra points due to the weight of the speakers?
http://meniscusaudio.com/ultra-points-p-209.html
There sure is a price different betweem the two. You can almost get an entire set of the "extra points" for the price of a single "Ultra Point". Other recommendations? Thanks. -
The extra points should work fine. The ultras are if you want to show off more
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »The extra points should work fine. The ultras are if you want to show off more
If there isn't any different in performance, I'd rather show off with the extra $140 in my pocket! :cheesygrin: -
audio_alan wrote: »Other recommendations? Thanks.
http://www.musicdirect.com/p-58810-track-audio-speaker-spikes.aspx -
Thanks F1nut! Those are some nice looking spikes. Now the decision is silver or brass... decisions, decisions.
I decided to call Meniscus Audio too. The guy said that the Extra Points would be fine, but cautioned that rocking the speaker on the smaller-shafted spikes could be a problem. But once they are in place, it shouldn't be a big deal... especially since the default shaft size for the SDA-SRS is 1/4"-20 anyway. -
I just pulled the trigger on a couple sets of the brass "extra points". I decided to go the cheaper route for testing them out. I might try other more expensive brands if/when I'm impressed...
I'll report back after I get them on my speakers and give them a listen. -
I use them on my LSIs and liked what they did. Do buff them a bit before you install them. Couple coats of laquer will help keep them shiny
Not silver, stainless steel and rated for 200 lbs. each! -
Yeah, I understand. I was more talking about the color of them, not the material they are made from. Although I suppose I should have said "silver or gold" - that would have been a better "apples to apples" comparison.
If nothing else, I'll throw these cheaper sets on my 1C's and 2B's, and then buy heavier duty ones for my larger SDA's.EndersShadow wrote: »I use them on my LSIs and liked what they did. Do buff them a bit before you install them. Couple coats of laquer will help keep them shiny
Yep, I was planning on doing that. I'm looking forward to testing them... -
Rated for 200 lbs. each!! I am getting these for my 2.3TL's. Thanks again Jesse.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Trust me Alan you will love the spikes it will change everything. Next you need to try some dynamat call me over and we can have a beer and knock it out in no time..:cheesygrin:
Sounds like a plan, Larry. I like the way you think! :biggrin: -
I know you've ordered, but it really depends on the application. If you are trying to pierce carpet and padding, "pointier" is the way to go. Then the thicker the carpet, the longer you want the spike.audio_alan wrote: »I've been slacking and still need to order spikes. For the original large SDA-SRS's (pre-1.2's, but same form-factor), are these sufficient?
If you are on a hard floor, the shape does not matter... but the color might... :cheesygrin:
Good caution by that CS rep on the tilting...audio_alan wrote: »I decided to call Meniscus Audio too. The guy said that the Extra Points would be fine, but cautioned that rocking the speaker on the smaller-shafted spikes could be a problem.
At what angle?...stainless steel and rated for 200 lbs. each!More later,
Tour...
Vox Copuli
