Spikes - they really are that good!
124»
  • sda2mike
    sda2mike Posts: 3,131
    edited January 2012
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited January 2012
    BlueFox wrote: »
    Some people think sonic improvements from vibration elimination are the same as improvements from better speaker wire and inter-connects; that is it really doesn't exist. Of course, they are wrong on both parts. I'm glad you are hearing the difference.
    For the next step, try putting all your gear on brass footers. I use the Mapleshade Micropoints on everything, and as I added the footers to each piece of gear the sound became clearer and clearer. It is amazing how much better the sound gets as vibration is reduced in each piece of gear in the chain.
    Have fun!
    Hopefully, I am reading this right - that BlueFox take is that spikes, speakerwire and inter-connects make a significant impact on fidelity. If so, as a cablemaker myself, I totally agree with this assesment. This is no myth. All of these items makes a significant impact.
    If you cannot hear the difference when changing speakerwire or interconnects, then two questions arrise -
    what cables are you using to swap one for another?
    and what gear is being used to drive your equipment?
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
    Toolfan66 Posts: 18,057
    edited January 2012
    A piece of gear does not always have to be expensive it just has to mesh with the other components in the chain, each tweak can bring forward the weakest link in the chain, that's helps one figuring out where to start next.
    SYNERGY can be a **** but it can also be fun.
    Never forget about room treatments/bass traps, and while your at it take a good look at the rack you house your equipment in if you don't think that can't be a weak link think again.
    Brass footers, Spikes, weight on top of your CD player, a well leveled TT, Dynamat, BlackHole, HiRez, SonicBarrier, the list can go on and on.
    Enjoy but do your homework before jumping into the deep end of the pool.
    BTW I'm still learning how to swim..:smile:
  • PolkMaster1
    edited January 2012
    Toolfan66 wrote: »
    And Tool - how do we get a hold purchasing the ToolForLifeFan Audio Rack???
    edited January 2012
    and tool - how do we get a hold purchasing the toolforlifefan audio rack???
    lol!!!
  • PolkMaster1
    edited January 2012
    Toolfan66 wrote: »
    lol!!!
    I was serious, along with getting that TFL AI Cabinet. :cheesygrin:
    BTW - I hope to get your tweeter brackets in my speakers by the end of this month.
  • PolkMaster1
    edited January 2012
    By the way - in case I wanted to drop by for a visit - where is Hell TFL? I can't get it to come up on my Garmin Nuvi or on Yahoo maps.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2012
    phoppmann wrote: »
    I spiked my SDA 2bs ..... Great improvement in bass! The 2bs have a hollow box frame on their speaker's base - I used a couple aluminum angle brackets (as long as the box frame) that I attached to the frame with through bolts, and then the two spikes were mounted to the horizontal section of each bracket. A MUST DO tweak!
    Welcome, phoppman...
    On carpet... yes?
    I assume the Al brackets are plenty stiff, but regardless depending on how you oriented them I could see some potential of them "ringing".
    Pics?
    More later,
    Tour...
    Vox Copuli
  • evhudsons
    evhudsons Posts: 1,175
    edited January 2012
    Thanks again Tour2ma! I once again have nice pressure rather than noise coming from my subs, and they sound much better blended for music. I had to research quite a bit on those Crankensteins. It's a funny brand name, and they are out of business but they certainly made my subs well.
  • evhudsons
    edited January 2012
    Finally,
    got it perfectly set, thanks a bazillion! I finally got that feel the bass rather than hear the bass setting back again, and now even better.
    Now I can listen at low levels even and get full bass through the air and it blends very very nice with my sda's. I put in Star Wars II to check it with the intro scene, awesome! But for music it's really now I perfect blend.
    thanks again for the explanations and advice! Priceless
  • Texun2
    Texun2 Posts: 10
    edited January 2012
    I was looking at spikes on parts express site this morning. Will they help on a tile floor? That system has a set of Klip Forte II's
  • sda2mike
    edited January 2012
    for my 2b's, i have the dayton spikes right to the tile - no discs...they don't scratch either...2b's are light compared to others and not all tile is created equal, so YMMV....sound-wise? one of the best mods i've done
  • Tour2ma
    edited January 2012
    Welcome Texun2... all the best members have numerals in their screen name (especially "2", right, Mike?)... so the pressures on... :cheesygrin:
    The reason to spike is universal... bedrock speaker stability. Spikes are a cheap enough tweak that there's no reason not to try them.
    More later,
    Tour...
    Vox Copuli
  • audio_alan
    audio_alan Posts: 770
    edited January 2012
    Tour2ma wrote: »
    DANG! I knew I should have been audio_alan2. haha
    I've been slacking and still need to order spikes. For the original large SDA-SRS's (pre-1.2's, but same form-factor), are these sufficient?
    http://meniscusaudio.com/extra-points-p-1292.html
    Or do I need to step up to the Ultra points due to the weight of the speakers?
    http://meniscusaudio.com/ultra-points-p-209.html
    There sure is a price different betweem the two. You can almost get an entire set of the "extra points" for the price of a single "Ultra Point". Other recommendations? Thanks.
    EndersShadow Posts: 17,704
    edited January 2012
    The extra points should work fine. The ultras are if you want to show off more ;)
  • audio_alan
    edited January 2012
    If there isn't any different in performance, I'd rather show off with the extra $140 in my pocket! :cheesygrin:
    F1nut Posts: 51,768
    edited January 2012
  • audio_alan
    edited January 2012
    Thanks F1nut! Those are some nice looking spikes. Now the decision is silver or brass... decisions, decisions.
    I decided to call Meniscus Audio too. The guy said that the Extra Points would be fine, but cautioned that rocking the speaker on the smaller-shafted spikes could be a problem. But once they are in place, it shouldn't be a big deal... especially since the default shaft size for the SDA-SRS is 1/4"-20 anyway.
  • audio_alan
    edited January 2012
    I just pulled the trigger on a couple sets of the brass "extra points". I decided to go the cheaper route for testing them out. I might try other more expensive brands if/when I'm impressed...
    I'll report back after I get them on my speakers and give them a listen.
    edited January 2012
    I use them on my LSIs and liked what they did. Do buff them a bit before you install them. Couple coats of laquer will help keep them shiny :wink:
    F1nut Posts: 51,768
    edited January 2012
    Not silver, stainless steel and rated for 200 lbs. each!
  • audio_alan
    edited January 2012
    Yeah, I understand. I was more talking about the color of them, not the material they are made from. Although I suppose I should have said "silver or gold" - that would have been a better "apples to apples" comparison.
    If nothing else, I'll throw these cheaper sets on my 1C's and 2B's, and then buy heavier duty ones for my larger SDA's.
    Yep, I was planning on doing that. I'm looking forward to testing them...
    edited January 2012
    Trust me Alan you will love the spikes it will change everything. Next you need to try some dynamat call me over and we can have a beer and knock it out in no time..:cheesygrin:
  • headrott
    headrott Posts: 5,496
    edited January 2012
    Rated for 200 lbs. each!! I am getting these for my 2.3TL's. Thanks again Jesse.
    Greg
  • audio_alan
    edited January 2012
    Toolfan66 wrote: »
    Sounds like a plan, Larry. I like the way you think! :biggrin:
  • Tour2ma
    edited January 2012
    audio_alan wrote: »
    I know you've ordered, but it really depends on the application. If you are trying to pierce carpet and padding, "pointier" is the way to go. Then the thicker the carpet, the longer you want the spike.
    If you are on a hard floor, the shape does not matter... but the color might... :cheesygrin:
    audio_alan wrote: »
    Good caution by that CS rep on the tilting...
    ...stainless steel and rated for 200 lbs. each!
    At what angle?
    More later,
    Tour...
    Vox Copuli
