TX-SR805 pre-out subwoofer not working
rhecker
rhecker Posts: 1
edited January 2012 in Troubleshooting
My receiver is not sending sigfnal to my subwoofer, I tried with another sub to discard issues with my subwoofer but the problem persist. Looks like there is no output from the reciver, any idea what coud be the cause and possible solution? Thks..
Post edited by rhecker on
    edited January 2012
    Is it turned on in the receiver ? Did you setup all the inputs ?
  • Cassidy
    Cassidy Posts: 87
    edited January 2012
    Make sure you are hooked up to the sub pre out on the Onkyo. The pre outs all have a shaded background. Others have mistakenly connected to the sub input.
    edited January 2012
    Good advice above. Two common mistakes are:
    1. Not telling the AVR there "is" a sub there.
    2. Running the sub cable to the Onkyo's SUB inputs rather than the sub PRE-OUT!
    Other possibilities: Sub LEVEL on the Onkyo--if set too low you won't hear anything from your sub!
    So go into all Sub-related menus and check all your settings. Also, check your cables, use a different cable, that is. And make sure that you're connected to the LFE "in" on the sub itself.
    Check sub "crossover Frequency", make sure it's around 80hz or so.
    If all of that "fails" then you probably do have a problem with the Sub-out itself, on the Onkyo and a look under the hood might be in order!
    Hope it's something simple!
    cnh
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2012
    Are you in Direct or "Pure Audio" mode?
    In either of these modes the sub will have no output.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
