Bi-Amping - Is it Worth It?
edited January 2012 in Speakers
Hi All,
I just purchased a pair of RTi12's for my fronts and a CSi5 for my center and have them hooked up to a Pioneer SC05 (130 watt/channel, 7.1) receiver.
1 - Do any of you think that I would benefit from "bi-wiring" the fronts and center? If so, how much of a difference do you think it will make? Does it seperate the highs from the lows?
2 - If you do recommend "bi-wiring" these, could you please describe how to go about doing it?
Many thanks to anyone that can help.
-Luke
Post edited by paperthin567 on
Welcome!
    edited January 2012
    Your topic is one thing and your questions are about another.
    Bi wiring is simply running two sets of speaker wire. Both sets hook up to the.same terminals on your reciever. Then on the speaker end one set hooks to the bottom set, and the other hooks to the top set. The major benefit is the removal of the metal connection straps between the top and bottom set of posts. You can achieve the same thing by into running one set of wires from your avr to the speakers. Then use a short piece of speaker wire to replace the metal jumpers.
    The main benefit is the removal of the metal jumper.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    edited January 2012
    Bi Amping is a whole different animal. With out using external amps and active crossovers between the avr and amps it is not worth it.
    The purpose of bi amping is to keep the high and low frequencies seperat. That way the amp for the low frequencies is not amplifing high frequencies and sending them to the woofers. The same goes for the mids and highs.
    The active crossover also allows you to control what frequencies goes to what part of the speaker.
    Bi amping with an avr is not worth it. You do not get to add up the wattage. Your still only feeding 130 watts to each speaker. With some recievers it is a step down in power because they put out less watts per channel when they have more channels to run.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    edited January 2012
    jbooker82 wrote: »
    How is removing the metal jumper a benefit?
    edited January 2012
    They're cheap and don't sound as good as they can. Using a small section of speaker wire or an aftermarket jumper can make a difference. It's a nice cheap/free mod to try, see for yourself.
    edited January 2012
    B Run wrote: »
    Yep it will only cost you a couple inches of speaker wire.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    edited January 2012
    jbooker82 wrote: »
    So I need to get 4 strips of speaker wire (2 sets total). Twist the ends together (positive and negative) of one end and plug into the receiver. The other ends, separate out and plug individually into the 4 speaker terminals on the back of each speaker?
    edited January 2012
    That seems like overkill unless you're using four conductor wire.
    First I tried this;
    Then I made these with four conductor wire;
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
    edited January 2012
    Like that, you don't have to use spades you can use bare wire or bananas.
    edited January 2012
    Yes. Two amps are better than one, unless you can muster up an amp with 500 wpc @ 8^. Your 12's are similar to my A9's and rated at 50 - 500 watts. It is a good thing to feed the monsters and keep them happy.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
    edited January 2012
    You don't need 500 watts to drive the 12's or 9's....period.
    edited January 2012
    tonyb wrote: »
    Thats true, but mine needed at least 200wpc to bring out the low end.
    edited January 2012
    Yeah, but I bet it'd be fun to drive the 12's or 9's with 500watts.
    edited January 2012
    Geoff4rfc wrote: »
    Yes, the more watts the better the sound overall.
    edited January 2012
    la9ers wrote: »
    This statement is absolutely untrue. I have heard some killer 10wpc or less tube amps that would blow away a solid state amp with 50 times more power.
    edited January 2012
    edited January 2012
    Yep my RTI A7's with a carver A-753x, 250 watts per channel playing at referance level (82 on my Onkyo TX-NR808) reaches 106-107 db. It is only useing around 60-120 watts (according to the gauges on the front of the amp).
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
Welcome!
Welcome!
