Arrived with damaged speaker grill
bscottberg
bscottberg Posts: 1
edited December 2011 in Troubleshooting
I just purchased a set of monitor 60s online from NewEgg.com and one arrived with a dent in the back edge and the speaker grill smashed. Their RMA policy requires the customer to pay for the return shipment. So before I spend $50 shipping this back for a replacement I wanted to know if I can get a replacement grill direct from polk either under warranty or as a separate purchase for less than the cost to ship. Also I am curious if should be concerned about problems with the speaker performance down the road assuming it took a blow during shipping. It looks just like the side back edge of the left side panel was dented in. I don't see any sort of a crack or gap where the side and back panels meet.
Post edited by bscottberg on
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Call them on Monday. Ask all of your questions, and I'm sure you'll be satisfied.
    Customer Service & Tech Support: polkcs@polkaudio.com
    1-800-377-POLK (7655)
    9AM-5:30PM EST Mon-Fri
    (410) 764-5470 FAX
    International +1-410-358-3600
    F1nut Posts: 51,783
    Closed Monday, call Tuesday, but really you should get the replacement from NewEgg.com.
  • Glowrdr
    Glowrdr Posts: 1,103
    I know that's newegg's policy, but I've called them out on it, and they've always provided me with a return label.
    I would try and contact Polk first, and if that is unsucessful - chat with a NewEgg CSR and I am sure you will be taken good care of. If you're going to have a problem, I'd say you are dealing with 2 of the best companies you could be.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • drumminman
    drumminman Posts: 3,396
    bscottberg wrote: »
    My take: if the speaker suffered the kind of impact that broke the grill and dented the back edge, through the shipping container, I would return it. Who knows what kind of hidden damage might have occurred. I'll bet if youlean on Newegg they'll make it right at no cost to you.
