Someone who has or can build a AI-1 Dreadnaught
brgman
Anyone that has the smarts to build one or even better has one i can borrow to see if it will work.
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
IIRC, it's just a matter of attaching a pin/blade cable to a small transformer. Not hard to do at all, the hardest part is cutting up a pin/blade cable !:eek:
i'll have to look at old threads.i know there is a transformer involved but i thought standard speaker wire went to and fromMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Look for Darqueknight's thread where he builds his, very detailed. Search for Dreadnaught
I had to re-read Darqueknight's thread a few times, but it's not difficult. The main thing is to get the correct transformer from Avenel.
Also, you can use speaker cable. For each speaker to transformer run connect the postive to the IC pin (or binding post if you've done that mod) and the negative to the negative BP for the lows - don't need to use the blade.
Are you wanting a dreadnaught for anon common ground amp? I'm thinking of building one for my common ground amp to see if it makes an improvement."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
