Anyone familiar with Coda?
brgman
brgman Posts: 2,859
edited December 2011 in Electronics
A buddy of mine is eyeing their amps.Looks like old threshold people but i know nothing about them.
http://www.coda.cc/home/index.php
I’M OFFENDED!!!!
Post edited by brgman on
  • inspiredsports
    inspiredsports Posts: 5,502
    Their product review page links to a quite a few publication reviews . . .
    http://www.coda.cc/product/index.php
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • brgman
    brgman Posts: 2,859
    Yea i saw that but 2007 is the most recent.A lot can happen in 4 years.
    Might be great stuff but i think my buddy should do his homework before dropping 12k on 2 mono blocks.
    He should buy the new carvers for that kind of $$
    I’M OFFENDED!!!!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I didn't like all their spec's for those mono amps. The slew rate really turn me down, for that money I would buy Parasound Halo JC-1 mono amps.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    heiney9 Posts: 25,629
    brgman wrote: »
    For that kind of money you can get Pass Labs used mono's and those, I'm sure, are far superior and have better support.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1328229387&/Pass-labs-XA100.5-Amplifier!
    I'd take these in a heartbeat over anything else on the planet.
    SCompRacer Posts: 9,269
    Coda makes excellent gear and has great support for their products. (At least they did when I needed it a couple years back). Even the gear they make and rebadge for others (like InnerSound). That bothers some folks that they make gear for others and rebadge it, but it absolutely positively has not stopped me from enjoying it. I've had their 03p phono stage, 02b pre amp and owned a couple of amps with the InnerSound badge. When InnerSound went under, Coda made some repairs for a bad InnerSound amp I picked up.
    There you go, an endorsement from a guy I trust.
    I still think for the price, there are other viable alternatives.
  • brgman
    brgman Posts: 2,859
    Thanks for all the great input.
    If he is sold on them all i can do is recommend looking at the others.
    I’M OFFENDED!!!!
    I sold an InnerSound/Coda amp to a guy in Taiwan. I was boxing it up and thought I'd better set it to their voltage so there would be no plug and play mishaps upon arrival. I broke the plastic tabs removing the fuse holder/IEC module. They sent me one Standard Overnight on my FedEx account so I could get the amp on its way. So I have good memories of Coda.
