Amp power supply caps
quadzilla
Anyone have any good brands to go with? I know of Black Gate, but they aren't available any more. So, who else? I'm looking for 5-600 uf range.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Arm: Rega 300
Post edited by quadzilla on
I can recommend Panasonic FC series and Nichicon HE's,or UCC LXV;s.All are low impedance 105 c deg. rated.I assume with the values your looking for they are not for the main filter bank's or coupling purposes?
Panasonic FCs have a very good reputation as a all around good choice for audio use. If they have them in your pin pitch and size then it would be a winner.SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp -
No, but I may upgrade the filter bank as well. The coupling caps are .22 uf Claritycap ESAs. I forget exactly what these caps do, but I do know they're not part of the filter bank, and basically provide "reserve power" to the power tubes. The guy that built them told me that he's learned that the tube rectification circuit can handle more capacitance that what he originally put in there (330 uf), and recommended I upgrade to something between 500 and 600 uf.Turntable: Empire 208
Arm: Rega 300
Speakers: SDA 2.3TL, heavily modified -
What would you benefit to up the capacitance? If the system was engineered for that amount I would upgrade if needed to the same rated capacitor.SDA2BTL
Marantz CD5004
Adcom GFA-545
Like I said, the guy told me he basically made a mistake and didn't put enough in there originally. He said the benefit would be a tighter bass response.Turntable: Empire 208
Arm: Rega 300
Ah so it,s vacuum state.:evil:in that case you can ignore my previous recommendation's since they are not likely to be available in the voltages you'll be looking for.
Yeah, should have mentioned these need to be 600V.Turntable: Empire 208
Arm: Rega 300
Jensen makes good ones with 500V rating.
If you really need 600V rating, Vishay/Sprague might be a reasonable choice.cristo
NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
(with Sonicraft/Solen/Mills crossover rebuild) -
Contact Chris at VH audio, I am sure he will provide feedback.Speakers: SDA-1C (most all the goodies)
Good recommendation on Chris VenHaus. Excellent recommendations and products.
Greg
