Amp power supply caps
quadzilla
quadzilla Posts: 1,543
edited December 2011 in DIY, Mods & Tweaks
Anyone have any good brands to go with? I know of Black Gate, but they aren't available any more. So, who else? I'm looking for 5-600 uf range.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
  • FTGV
    FTGV Posts: 3,650
    I can recommend Panasonic FC series and Nichicon HE's,or UCC LXV;s.All are low impedance 105 c deg. rated.I assume with the values your looking for they are not for the main filter bank's or coupling purposes?
  • PreCd
    PreCd Posts: 786
    Panasonic FCs have a very good reputation as a all around good choice for audio use. If they have them in your pin pitch and size then it would be a winner.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
    Bottlehead Quickie Tube Preamp
  • quadzilla
    FTGV wrote: »
    No, but I may upgrade the filter bank as well. The coupling caps are .22 uf Claritycap ESAs. I forget exactly what these caps do, but I do know they're not part of the filter bank, and basically provide "reserve power" to the power tubes. The guy that built them told me that he's learned that the tube rectification circuit can handle more capacitance that what he originally put in there (330 uf), and recommended I upgrade to something between 500 and 600 uf.
    Arm: Rega 300
  • PreCd
    PreCd Posts: 786
    quadzilla wrote: »
    What would you benefit to up the capacitance? If the system was engineered for that amount I would upgrade if needed to the same rated capacitor.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • quadzilla
    Like I said, the guy told me he basically made a mistake and didn't put enough in there originally. He said the benefit would be a tighter bass response.
    Arm: Rega 300
  • FTGV
    FTGV Posts: 3,650
    Ah so it,s vacuum state.:evil:in that case you can ignore my previous recommendation's since they are not likely to be available in the voltages you'll be looking for.
  • quadzilla
    Yeah, should have mentioned these need to be 600V.
    Arm: Rega 300
  • Face
    Face Posts: 14,340
  • cristo
    cristo Posts: 231
    Jensen makes good ones with 500V rating.
    If you really need 600V rating, Vishay/Sprague might be a reasonable choice.
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • thsmith
    thsmith Posts: 6,082
    Contact Chris at VH audio, I am sure he will provide feedback.
  • headrott
    headrott Posts: 5,496
    Good recommendation on Chris VenHaus. Excellent recommendations and products.
    Greg
