Receiver crossover question
bokdaddy
bokdaddy Posts: 176
I've been using my Denon AVR-1803 for a few months now and I still have a question about the crossover setting. It can be set to 80 hz, 100 hz, or 120 hz. Does this mean that below the crossover frequency the sound is sent to the subwoofer AND the speakers or just the subwoofer. Since I'm using RTi38's in the front I'm worried that I'm losing bass potential.
Any help would be greatly appreciated.
Home:
Denon AVR-1803
Polk CSi30
Polk RTi70
Polk RTi28
Polk PSW-303
Car:
Kenwood KDC-BT945U
RF Punch P400-4
Polk MM6501
Polk MM651
RF Punch P300-1
Boston Acoustics G312-4
Post edited by bokdaddy on
  • Pauly
    Pauly Posts: 4,519
    edited April 2004
    yes you are correct. it sends below to the sub, but why are you worried about losing bass potential from the 38's? Your not going to be getting a whole lot of bass from those more of the mid and let the sub pick up the rest. IMO i would set it at 80..or you could just try all of them and see what sounds best to your ears
    Spaz
    Life without music would
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited April 2004
    Agree, I'd go with 80hz and not look back.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • dorokusai
    dorokusai Posts: 25,640
    edited April 2004
    Yea, what they said :)
  • bokdaddy
    bokdaddy Posts: 176
    edited April 2004
    Thanks guys, you've probably answered that question 8 million times. The only reason I'm worried about losing bass is because my subwoofer is just the PSW202 which as you know, only goes 4 hz below the RTi38's. So I've pretty much been trying to find the best way to blend them together.
    Home:
    Denon AVR-1803
    Polk CSi30
    Polk RTi70
    Polk RTi28
    Polk PSW-303
    Car:
    Kenwood KDC-BT945U
    RF Punch P400-4
    Polk MM6501
    Polk MM651
    RF Punch P300-1
  • dorokusai
    edited April 2004
    I have the same setup, and it works fine.
  • bokdaddy
    bokdaddy Posts: 176
    edited April 2004
    Doro, may I ask how long you have had your setup? Maybe you could answer another question.
    I've started to grow curious of the frequencies below what the PSW202 can handle. A friend of mine (he may have been B.S.'ing for all I know) told me kick drums can go down to 40hz these days, so I may not be hearing a good portion of my music or my movies. Have you ever felt like you're missing some sound with the 202 or do you think the extra range is not really worth an upgrade?
    Home:
    Denon AVR-1803
    Polk CSi30
    Polk RTi70
    Polk RTi28
    Polk PSW-303
    Car:
    Kenwood KDC-BT945U
    RF Punch P400-4
    Polk MM6501
    Polk MM651
    RF Punch P300-1
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited April 2004
    There is a whole world of bass in the 35-15 Hz region. It must be experienced first hand to be fully understood and appreciated.
    Consider upgrading as time and budget allows. Until then, make the best with what you have and enjoy it!
    Agree with the 80 Hz xo on the 38's. Even though the rated extension might only be a little better, the 202 probably moves more air than the 38's in the 35-50 Hz range.
    SVS
  • gmorris
    gmorris Posts: 1,179
    edited April 2004
    No one has yet mentioned that with the 80 Hz X-over set, you still need to set the Front L&R to SMALL to be sure they are high passed at 80 Hz. If you leave them as LARGE, you will be getting a full range signal to the 38's.
    Double check how you have the Front L&R set up.
    Bob Mayo, on the keyboards. Bob Mayo.
  • Willow
    Willow Posts: 11,340
    edited April 2004
    I have the 202 and it does a decent job for the time being, there is better out there but also worse...work with what you have for the time being
  • dorokusai
    edited April 2004
    Bok - Do I feel as though I am missing something? Hell yea :D but it serves its purpose for now. I like my PSW202, so it really hasn't been a huge priority to upgrade it right now.
    A good subwoofer will show you things that you never thought existed.
  • Grimster74
    Grimster74 Posts: 2,577
    edited April 2004
    Doro had a prime example of this just this past weekend.:D
  • Dr. Spec
    edited April 2004
    Bok:
    If you feel an upgrade coming on, send me a PM. I might have a deal you can't refuse.
    Doc
    SVS
