Krell KAV-250A Power Amp
    Toolfan66 Posts: 18,068
    edited December 2011
    I would love to hear that Krell, my heart and ears are really set on a Pass Labs amp my only problem is the depth of it and putting it in the middle of the floor is not an option right now, maybe someday.
    heiney9 Posts: 25,443
    Depth??? I don't think the Pass amps are that much deeper than a comparable high end amp. Are they? I know my Aleph is about 4-6" deeper than the Adcom 545 I had. But I don't think the Pass stuff is larger than most. I could be wrong since I never really was concerned about that so probably never paid any attention.
    The 250 is like 22" deep as well as the 350 but I don't feel these amps were made to be in a rack. My shelves are 19" deep.
    I see, never had my gear in a rack so like I said, I was probably oblivious to that fact. They get so hot you couldn't keep them in a rack anyway so even if your rack could fit 22" in depth unless it was really open the heat would be too much.
    Agreed!!! That's why I don't have one just yet. I knew it would be a bad idea.
  • falconcry72
    falconcry72 Posts: 3,580
    heiney9 wrote: »
    ...Krell can be a little too forward for my tastes ...
    Well, the KAV-250a is unrelenting, that's for sure. I think it would do well with a vinyl, reel to reel, or other fully analog system. This amp will do a poorly implemented digital source no favors whatsoever! Luckily, my NFB-7 is a warm, dynamic, robust sounding DAC. That DAC, paired with the ARC preamp, makes a good combo for this Krell. As I said earlier, you'd have to be careful when pairing equipment to this amp. The Parasound is easy to pair, and will make anything sound good. The Krell, on the other hand, needs thought to be given upstream.
    It is accurate... almost to a fault... almost.:cool:
    H9, when you've heard Krell amps in the past, were they running off Krell preamps or other mfgs? Ever heard a Krell amp on a tubed preamp?
  • falconcry72
    Toolfan66 wrote: »
    Interestingly, the deepest piece in my rack is my DAC, at 17.5". The Krell is 15", the Parasound is 16" (19" with handles).
    tonyb Posts: 33,072
    I have heard that exact amp but only paired with SS gear. I would imagine tubes would benefit it greatly. That amp has balls, very dynamic, and seems best paired with lower efficient speakers. The harder the speaker is to drive, that amp shifts gears and can be very good, though not to my personal taste. On SS gear, it is very detailed as observed, but for me still lacks that organic tone and air. Maybe it has to do with age and how your ears change from your youth. Krell makes nice stuff, if that sound is up your alley.
  • falconcry72
    tonyb wrote: »
    See, I don't really know what sound is up my alley yet, which is why I have to keep experimenting with gear. There are a handful of manufactures that will have to make their way through my system one way or another, just so I can familiarize myself with their sonic characteristics. Krell was one of those brands. Check.:wink:
    edit:
    In fact, I wasn't looking for an amp when I came across this Krell. I was sure that my next amp would be a Bryston (6 months or a year down the road), but I stubled upon a good deal and said "ah, what the hell...":biggrin:
    I believe the last time I heard a Krell the associated gear was Meridian.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    By the sounds of it the krell would be exactly what is needed for HT. I have heard magazine reviews about krells being too much then paired up with tube pre's to tame them
  • Drenis
    Drenis Posts: 2,871
    When I bought my TV stand, I bought it with the intention of ensuring I could fit my Pio Elite receiver which is VERY deep with out it sticking out the front. I accomplished that and my AVR, my Carver, even my HTPC with it's ridiculous deep case fits nicely without sticking out. And it has air around it to cool. :)
    Back on topic, I'd love to hear a Krell sometime.
  • nspindel
    nspindel Posts: 5,343
    Anyone in the NYC area who wants to give a listen to a Krell rockin the 1C's, just let me know. Paired up with my W4S DAC2 and Eddie Current Balancing Act, it really leaves me desiring very little.
    SCompRacer Posts: 9,112
    CP member Ed (ESavinon) is a Krell fan. IIRC he has a KSA-250 that Carl (schwarcw) had. Carl got it from his friend Dipole Dan who used it to power his Carver Platinum Amazings and Apogee Centaurus Minors. Ed had it connected to a pair of modded Carver ASL-III"s that was passed around from Norm, to me, Noel, Ricardo, Carl then Ed. I think the order is correct and I didn't miss anyone....
    Njoy!
  • nspindel
    The old KSA amps make the newer KAV amps look like toys. That's a bad **** amp!
    The KSA's were multi-purpose amps. You could listen to music while making breakfast on them.:twisted::cheesygrin:
  • falconcry72
    SCompRacer wrote: »
    Njoy!
    Hey, I think I've met Dipole Dan! Carl put in touch with his friend Dan who I ended up buying some Maggies from. Good guy, small world!:biggrin:
  • falconcry72
    SCompRacer wrote: »
    lol.:lol:
    tonyb Posts: 33,072
    Well, thats what it's all about,experimenting. Congrats and rock on.
  • schwarcw
    schwarcw Posts: 7,358
    SCompRacer wrote: »
    Njoy!
    Rich, you have the order correct! Ed still has the AL-III's and the bad **** Krell KSA-250. In fact, I think he bought two more:eek:
    Yes Ben! You have met DiPole Dan!!
    nspindel wrote: »
    Oh! You are so right!
    Check out the pictures of Dan's KSA-250. I would have kept it except the thing was so big!! Long and heavy! This 140 lb. pure Class A amp needed it own 20 amp circuit. It could make a pair of swimming pool speakers sound good. It has so much power it melted the fuse hoder on the AL-III. Check out the Pics, the second picture give you aperception of how deep this amp is. It will not fit in a cabinet, it has to sit on the floor by itself, with a lot of ventilation. Stable to 1 or 2 ohm it is dead quiet, very dynamic and has the power to start a revolution in a small country!!
    Carl
  • falconcry72
    Nice amp, Carl!:smile:
  • falconcry72
    Hey, what do you guys think about the Rotel 1090 in comparison to the Krell KAV-250a and parasound HCA-2200mkii mentioned here???
  • schwarcw
    There really isn't a comparison Ben. Seriously, both of those other amps are toys compared to the Krell. The Rotel is big, but it won't deliver the sound you want. I love Parasound, but that amp is in a different league than Krell. The KAV vs the KSA? Just look at the pictures side by side. The KSA-250 is like a man playing with boys. These 20 year old amps still sell for around $2,500 - $3,000 (or more) and are worth every penny. I would even buy a Krell KSA-100 before I bought the Rotel, Parasound or the smaller KAV.
    Carl
  • James Zep
    James Zep Posts: 19
    edited October 2012
    Hi everyone,
    I’m a newbie here on Polk forum and actually I register because of this thread. I won’t introduce me too much but just simply say hello everyone and tell you how mucho I appreciate this community and how much I’m glad to be here.
    So I’m having exactly the same dilemma: I have to choose between these two great amplifiers. I’ve been trough all the discussion and I can’t really decide. On one side I’ve got a Krell KRC3 as preamp so esthetically the KAV 250a/3 could be a great match even if sonically, following what has been pointed out, it might be a little bright or kind of too much “in your face sound”. On the other hand this Parasound is pretty cool. Less reputation than Krell but this is a great model. And it looks like specs don’t really help (The Parasound is a true dual mono but it does not, for example, double down at 4ohm, though I know I don’t need that). Plus I don’t pay too much attention to specs.
    I know a lot has been written and I was going for the Parasound but the last comment from SCHWARCW makes me reconsider my decision.
    “There really isn't a comparison”
    “I love Parasound, but that amp is in a different league than Krell.”
    How can you be so sure of that?
    How many of you guys believe so?
  • CRESCENDOPOWER
    CRESCENDOPOWER Posts: 153
    edited October 2012
    Yes, within the "adequate" system Krell can simply destroy Parasound. Best to refer to post #15.
