sono tube sub
goingganzo
goingganzo Posts: 2,793
edited March 2002 in Technical/Setup
any one hear of a sono tube sub? i was surfing and found some they look cool
Post edited by goingganzo on
  • lax01
    lax01 Posts: 496
    edited February 2002
    Looks like a SVS brand sub woofer. They are made like that.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    SVS and HSU make some killer models, and they are very big in the DIY arena.....
    Big plus is the HUGE amount of airspace the driver can work with......
    Cheers,
    Russ
  • goingganzo
    svs what is that i looked for them but could not find them
  • RuSsMaN
    svs
    R
  • mikemokr
    mikemokr Posts: 150
    edited March 2002
    The SVS sounds even cooler than it looks. I have the 20-39PC and it produces exceptionally clean bass, not boomy at all. Great bang for the buck -- for $750 you get response down to 20 Mhz.
    Main problem is if you have a cat. I've seen this sub described as "the golden scratching post from God."
    Main HT (family room): Polk Monitor 7 (1987-original owner) (L/R) / CSi40 (C) / RTi38 (SL/SR) / SVS 20-39PC (sub), Outlaw 975 pre/pro / Outlaw 7075 amp, Oppo BDP-93 Blu-ray, LG 42LM5800 teevee
    2ch (family room): CRS+ (1987), Outlaw 1050 AVR, Denon DCM-420 CD
    Kitchen satellite 2ch: Polk M3II, Topping TP-20 Tripath amp fed from 975 rec line out
    Home office: Model 5 (1978-Danish Peerless), Lepai 2020A+ Tripath amp fed by laptop dock
    Awaiting assignment: PSW202 (NIB) to be wired inline in home office rig; Monitor 5JR (1988), Model 4 (1983-US Peerless)
  • Aaron
    Aaron Posts: 1,853
    edited March 2002
    Wow! My tweeter doesn't even go that high!
    Aaron
  • mikemokr
    mikemokr Posts: 150
    edited March 2002
    I have a forum protocol question here. Which of the following is the appropriate action for someone in my situation?
    1) 'fess up to a buffoonish mistake, perhaps with some lame excuse like "obviously I spend too much time around computers -- REALLY REALLY OLD computers."
    2) try to distract attention with a witty albeit nonsensical reply like "Maybe this explains why my dog keeps trying to hump the sub."
    or
    3) go back and edit my post to correct "Mhz" to "Hz" and then come back here and say, "Aaron, what the HELL are you talking about?"
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited March 2002
    Mike,
    I like this one better:
    4) The "M" in MHz stands for "Micro-Mega" (one millionth of a megahertz), which would equal Hz.
    I replaced my Polk PSW650 sub with a SVS CS Ultra last month. It is a much better match for my SDA 1C's. It is not the least bit boomy and performs well with both music and movies.
  • Aaron
    Aaron Posts: 1,853
    edited March 2002
    You did a fine job of handling that one, Mike. I applaud you.
    Aaron
  • joe logston
    joe logston Posts: 882
    edited March 2002
    what size is the driver or drivers & deminsions h w d & weight amp power
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • jimi64
    jimi64 Posts: 85
    edited March 2002
    www.svsubwoofers.comor ya can read up on them at www.hometheater.com.At HTF ther are links to DIY sonotube projects,more bang for the buck if you like to build your own.
  • joe logston
    edited March 2002
    . rt-7 mains
    rt-20p surounds
    2- psw-650 , subs
  • mikemokr
    mikemokr Posts: 150
    edited March 2002
    After the last fiasco I hesitate to jump back in on this thread, but here goes anyway.
    Looks like I'm about to get "obsoleted." At http://www.svsubwoofers.com/svspci.htm it is announced that a new "PCi" (as in "improved") series is about to debut. The model I bought a few months ago has a 190w amp and I paid $655 for b-stock (and boy was I proud of myself); the new 20-39PCi will be 320w and go for $649 new. ahhh well, mine isn't going to sound any worse because of it ...
    ok, my last post on the polk forums about some other company's subs.
  • ncstatesman
    ncstatesman Posts: 145
    edited March 2002
    Mike,
    Don't worry, I have an SVS 16-46 I bought in Dec and I pre ordered the new improved driver for my sub - this is the same driver that's being installed on the new PCi line of subs that replace the PC line. The cost is $79 for the new driver if I return the old driver to SVS, otherwise, its $129. I don't have any specs on this new driver, but it does improve headroom (more dB) and low end response - for $79, I think it's a great bargain because the improvment will be apprciable. I too have the 650 sub, it's not a bad sub, it just doesn't reach the low end and i no longer really need it because the SVS is more than enough in my HT room (12x19x8)
  • mikemokr
    mikemokr Posts: 150
    edited March 2002
    thanks for the info. Did you give any thought to swapping out the amp too?
    (should resist upgrade impulse here ... remind myself i'm very happy with how it sounds and it's already putting cracks in the walls ... should buy polk rears and centers first ... uh-huh uh-huh)
  • mikemokr
    mikemokr Posts: 150
    edited March 2002
    fyi, SVS got back to me and said an amp swap is not possible due to size differences.
