How Many Use Bypass Mode On Their Gear?
PreCd
PreCd Posts: 786
edited December 2011 in Electronics
I was wondering how many of you who have bypass modes on your gear actually use it or do you prefer the ability to manipulate the music? The most direct path of the music to your speakers by using bypass mode is a more pure form of the signal but I have used both on my preamp and CD player and both have their pros and cons I think.
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Post edited by PreCd on
  • steveinaz
    steveinaz Posts: 19,546
    When you say "bypass" do you mean bypassing tone controls? I haven't had tone controls for 10 years....
    Every layer of "processing" you can eliminate, gets you closer to the music--so generally, it's best to run as direct as possible, unless you've got some serious room acoustics issues.
    heiney9 Posts: 25,503
    No tone controls for 20+ years. In fact sometimes when I'm not using my tube pre-amp I run 100% passive.
  • PreCd
    PreCd Posts: 786
    steveinaz wrote: »
    Yep thats it. I have had my setup like that for the little time I have had it. Used tone controls some to see what the differences were, are but I am currently bypassing those tone controls. My CD player also has a bypass mode which I am currently using.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • PreCd
    PreCd Posts: 786
    heiney9 wrote: »
    What do you mean by running 100% passive?
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • steveinaz
    A passive pre adds no gain to the signal--it passes it straight on to the amp. I also run a passive linestage (pre).
    "preamp" is really not the correct term in this context, as that implies there is some "pre"amplification going on; which passives do not do. "Linestage" is more correct when speaking of a passive device.
    If your cd player has it's own volume knob (or if your amp does) you can experiment with plugging your player directly into your amp to hear what it sounds like to run passively.
  • PreCd
    PreCd Posts: 786
    steveinaz wrote: »
    Hm? I wonder if the bypass mode on my Adcom GFP-565 is passive? I think I remember reading that it was. I will check that out tonight.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
    Most if not all pre-amps are active, in that they manipulate the input signal through a few to several stages to amplify the tiny input signal to achieve gain. Each gain stage alters the signal. A passive pre-amp doesn't use any active gain stages. The signal flows in, goes through the volume pot and out to the amplifier. It's the simplest signal path plus it's the least altered. Passive pre-amps can be hard to integrate because of the lack of gain but if the amp and pre can work together the results are quite different than using an active pre-amp.
    Some material I prefer the sound of passive most I prefer active, but it's nice to go minimalistic once in awhile just to change things up.
    PreCd wrote: »
    It's not. Bypass simply bypasses the tone controls. The Adcom GFP750 preamp has active and passive stages.
  • steveinaz
    PreCd wrote: »
    No, it's still going thru preamplification stages. These "electronics" are absent in a passive linestage. My passive (placette) does nothing but control volume, and it does that with an array of Vishay resistors. Since most sources provide 2 volts or better at their outputs, amps that have an input sensitivity at, or below this can play at full volume without the need of a preamplifier stage. For example, my Parasound amp has an input sensitivity of 1.7 volts to achieve maximum output.
  • PreCd
    PreCd Posts: 786
    Nope. My Adcom GFP-565 is not passive in bypass mode. <br>
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
    Passive isn't all that it's cracked up to be and, IMO, is 100% dependent on the source material.
  • PreCd
    PreCd Posts: 786
    steveinaz wrote: »
    You are correct. Well this is still better than running it through the many capacitors inline.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • steveinaz
    heiney9 wrote: »
    ...and the passive linestage design. I have been extremely satisfied with the Placette, and aside from the hokey binary volume indicator (like anyone can make sense of that) it's provided incredible transparency and linearity.
  • Joe08867
    Joe08867 Posts: 3,919
    Bypass helps get you closer but get something with out the tone controls all together gets you much further.
    I haven't had Tone Controls in 10-15yrs now. It's all about the source.
  • Danny Tse
    Danny Tse Posts: 5,206
    I want my music direct and pure....I think I can handle it.
  • Gadabout
    Gadabout Posts: 1,072
    My 2 channel setup uses a TVC (Transformer Volume Control). 2 knobs. I for input switching and 1 for volume. The other systems are using some kind of Pre Amp that wouldn't be considered passive.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    There's tone control on equipment??
    Most be something new! I don't seem to have any. :sad:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • emy
    emy Posts: 7
    My CD player has a bypass mode which I am currently using.Don't know the effect without them.I Like pure music from my car dvd
