Spikes - they really are that good!
24
    Toolfan66 Posts: 18,057
    edited December 2011
    Spikes should be one of the first tweaks done IMO!!!
    Spikes Rule not just for speakers but equipment racks and gear as well especially the CD player..
  • ratster
    ratster Posts: 324
    Are you guys refering to Meniscus Audio in Grand Rapids,MI ? Does it matter which spikes you use as long as the threads match? Seems like I read somewhere in another thread that Polk uses 1/4 X 20 Does that sound correct?
    Thanks,
    Rhett
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • drumminman
    drumminman Posts: 3,396
    ratster wrote: »
    Thanks,
    Rhett
    Yep, 1/4 x 20.
  • deronb1
    deronb1 Posts: 5,021
    I have outriggers with rubber feet on my Rti12s. They sit on carpet. Do I need a solid base and then add spikes?
  • dorokusai
    dorokusai Posts: 25,576
    Toolfan66 wrote: »
    I isolate all my components aside from the amp, which I would if it didn't weigh 105lbs so there is no need. This is an easy, cost effective tweak when it comes to audio, that most ppl forget or don't bother to do.
    Check out Bright Star Audio. I use them almost exclusively for my system components.
  • ratster
    ratster Posts: 324
    drumminman wrote: »
    Yep, 1/4 x 20.
    Thank you,sir.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
  • ratster
    ratster Posts: 324
    I'm leaning towards these
    http://meniscusaudio.com/extra-points-p-208.html
    Good choice? Or would those with a hell of a lot more knowledge then me recommend something different.
    Thanks again,
    Rhett
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
  • dorokusai
    Great choice and they have a very good relationship with Club Polk actually. I setup a group buy months ago and it went VERY well to say the least.
    EndersShadow Posts: 17,704
    dorokusai wrote: »
    LOL, they were out of stock for like 2 months straight as a result. I picked up 2 sets of them. Havent found a use for the 2nd set yet.
    Very good build quality on them, and they were very responsive to me (had an issue with my order they resolved start to finish in 15 mins).
  • dorokusai
    LOL, yeah we destroyed their inventory for sure. Hell we sent them 135 pairs of spikes worth of business, in one week once the discount was setup....just from OUR forum!
    dorokusai wrote: »
    So what was the final tally on total orders from the forum? I never did hear....
  • dorokusai
    I'm not exactly sure but from the posts and offline messages it was about 135 or more. I know Mark was happy with the offer he and I worked out and subsequent business he received. I meant to order some but never did...oh well, maybe next time.
  • steveinaz
    steveinaz Posts: 19,545
    I've found that spiking/weighting optical drives is almost as significant as spiking speakers. Years ago I played with mapleshades' heavy hats/cone feet with my CEC, the results were pretty substantial.
  • dorokusai
    Agreed Steve...transports really benefit from isolation and weight.
  • bikezappa
    bikezappa Posts: 2,463
    Added spikes to my SDA 20 years ago when I had better hearing.
    Couldn't tell the difference with or without.
    Can damage the floor.
    Moving the speakers left or right in room made a big difference however.
    Just my opinion.
  • steveinaz
    I think carpeted rooms benefit most from spiking.
  • audio_alan
    audio_alan Posts: 770
    ratster wrote: »
    Are these good enough for carpet, or is a sharper spike recommended?
    So it sounds like you wouldn't even need to use the inserts - just unscrew the plastic feet, and screw in the new brass ones, right?
    I assume these are heavy duty enough for the large SDA-SRS's?
    Thanks.
    audio_alan wrote: »
    They work fine on my LSi 15's on carpet :smile:
  • steveinaz
    For another step-up, try tile on top of carpet, then spike the speaker stands:
  • skrol
    skrol Posts: 3,450
    I have always used the spikes that came with my RTA11TL's. Would upgrading the spikes make much improvement? If so, I see parts express sells some rather affordable spikes would they be an upgrade?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • steveinaz
    I doubt different spikes (unless your oems are plastic) would make any noticable difference.
  • evhudsons
    evhudsons Posts: 1,175
    I am using the cheaper but sharper spikes on my speaker stand as for some reason it works better. I ordered a set from meniscus which I am using for my components. It helped and it looks great and gives a little bit extra airflo underneath. I'm going to get another set so I can use on my cd player as well. Good good heavy brass. Great company and service.
    Don't forget to put the coupon code "polkme" when checking out.
  • apc
    apc Posts: 779
    Installed the spike that came with this particular set of speakers. Seems like there may be a little more punch, but I need to play some more familiar CDs. So far, I've only listened to a couple of Christmas albums. I think they are solid brass and really dig into the carpet. How much clearance should I be seeing between top of carpet and bottom of speaker or is any clearance the main thing?
    Husband, Father, Son, Brother, Friend.
    Just above the carpet is fine.
    F1nut Posts: 51,766
    steveinaz wrote: »
    Steve, the spikes would be much more effective piercing the carpet than sitting on the tile as the tile is basically floating and therefore not coupled to the floor.
    F1nut Posts: 51,766
    evhudsons wrote: »
    That's because the sharper spikes are piercing the carpet. It's important to get the right spikes for the application.
  • gordynor
    gordynor Posts: 6
    Confession: I'm new to the spike/isolation game... :rolleyes:
    I just recieved my very first pair of Polks (RTi A3) and have them sitting on my desk and a horizontal bookcase in my office. I don't have the option of moving them to stands on the floor given the room layout (but they're positioned well, directed towards me while I sit at my desk). I assume spikes wouldn't be recommended for on top of a desk/bookshelf, so I bought some 3/4" Sorbothane half-rounds and installed 4 on each speaker.
    My question: Should I spike, even on top of these surfaces? Is Sorbothane a good choice for isolating the speakers? Any other recommendations?
    Daniel
    gordynor wrote: »
    Daniel
    For nearfield listening (which is what I assume your doing) you might actually want to try putting them on these:
    http://www.amazon.com/Auralex-SpeakerDude-Speaker-Isolation-Platforms/dp/B00266HBSU/ref=sr_1_4?ie=UTF8&qid=1323883302&sr=8-4
    It accomplishes the same thing your current Sorbothane half-rounds do, but also angle the speaker up for a better positioning.
  • gordynor
    gordynor Posts: 6
    Thanks for the tip on those. I've seen those in friends' studios but kind of forgot about them. I don't know if they would work in my case since the A3's are about 15" long and have a teardrop shape... the flange may get in the way. Still, there's a Guitar Center nearby - I may try them.
    But you would agree that Sorbothane is a good thing to be using for on top of a large piece of furniture?
    F1nut Posts: 51,766
    I wouldn't use Sorbothane under speakers. The idea is to couple the speaker to whatever it's sitting on, not de-couple it, which is what Sorbothane really does. Also if you are not aware, Sorbothane stains whatever it comes in contact with...yuk!
